Old 11-03-2011, 06:28 PM
pkhoosh pkhoosh is offline
Send a message via AIM to pkhoosh Send a message via Yahoo to pkhoosh
biopac networking
I'm trying to modify the code in the reference manual to import biopac data channels into a common data file that Vizard records.
The first problem is that Vizard running on computer1 doesn't recognize the AcqKnowledge software running on the networked computer2 (I get an error that there's no module named acqserver). When I try to 'manually' connect to computer2 from the Vizard computer:
viznet.client.connect('192.168.10.1')
the command returns false
I appreciate any suggestions.
# test to write biopac data to file
import viznet
if viznet.client.connect('192.168.10.6'):
    print 'Connected'
viz.addNetwork('192.168.10.6')
viznet.server.start(port_in=9999)
import acqserver
###### NETORK SETUP #######
acqServer = None
useAcqServer = False
def useAcqServer():
	# setup network connection
	global acqServer, useAcqServer
	try:
		acqServer = acqServer.ACQServer()
		acqServerList = acqServer.findAcqKnowledgeServer()
		if not len(acqServerList):
			return
		# set ip and port
		(ip,port) = acqServerList[0]
		acqServer.setAcknowledgeServerInfo(ip,port)
		#work around for acqserver problems
		acqServer.changeDataConnectionMethod("multiple")
		acqServer.changeTransportType("udp")
		acqServer.changeMostRecentSampleValueDeliveryEnabled("calc",0,True)
	except Exception:
		return
	useAcqServer = True
################################# MAIN CODE #################################
useAcqServer()
################################# END MAIN CODE #############################
################################# Callback functions ########################
def onKeyDown(key):
	print acqServer.getMostRecentSampleValue("calc",0) # Print the incoming data point
	print "Z(t) Raw: " , acqServer.getMostRecentSampleValue("calc",1)
	print "ECG: " , acqServer.getMostRecentSampleValue("calc",2)
	print "Blood Pressure: " , acqServer.getMostRecentSampleValue("calc",4)
	print "dZ/dt: " , acqServer.getMostRecentSampleValue("calc", 41)
Old 11-16-2011, 05:26 PM
Do you have any virus scanners/firewalls enabled? If so, try disabling those.
Old 07-18-2012, 06:16 AM
amaze12 amaze12 is offline
I also cannot find the acqserver module, can you tell me how you fixed it?
Old 08-02-2013, 04:37 AM
chezz chezz is offline
hello..
i am facing the same problem... even disabled the firewall but still face problem in importing acqserver.
please help if your problem was solved.
Old 07-27-2018, 11:15 AM
Vishav Vishav is offline
Anyone get any solution. I am facing same problem.
ImportError: No module named acqserver
biopac, networking
Biopac Parallel Port Writer Error: missing INPOUT32.dll mmatlock Vizard 1 06-30-2010 02:04 PM
Networking Multiple Computers Ikslawok Vizard 1 02-23-2010 09:08 AM
Two questions (networking) TrashcanPatrol Vizard 5 05-07-2009 01:46 PM
networking nickyee Vizard 1 09-18-2006 04:53 PM
active avatar functions while networking crazyrusso Vizard 1 11-18-2004 01:08 PM
