Old 02-11-2018, 12:24 PM
VizMars VizMars is offline
What causes the ghosting in our cave?
Hi all,
in our experiment we want to show participants different 3d scenes and track their eye movements. They are seated 70 cm in front of a 3D monitor (display width: 59.773 cm; display height: 33.622 cm) wearing shutter glasses (NVIDIA 3D Vision2).
Everything seems to work fine with Vizard's scenes (e.g., 'piazza.osgb'). However, when we use our own scenes there is severe ghosting. We tried changing the contrast, applied gamma correction, changed the IPD, the fusion distance and the stereo overlap but neither did really help. So, we are running out of ideas where the ghosting effcet comes from.
Is there something wrong with our code or are there some attributes of the scenes that we have to change?
Please find the script of our cave definition below and here is one of our scenes:
https://drive.google.com/file/d/16Ve...?usp=drive_web
import vizfx
import vizcave
CAVE_WIDTH = 0.59773 # display width
CAVE_HEIGHT = 0.33622 # display height
DISTANCE = 0.70 # head to display = display to wall
viz.setMultiSample(8)
viz.go(viz.QUAD_BUFFER|viz.FULLSCREEN)
PowerWall = vizcave.Wall(upperLeft=[-CAVE_WIDTH/2.0, CAVE_HEIGHT/2.0, 0],
						 upperRight=[CAVE_WIDTH/2.0, CAVE_HEIGHT/2.0, 0],
						 lowerLeft=[-CAVE_WIDTH/2.0, -CAVE_HEIGHT/2.0, 0],
						 lowerRight=[CAVE_WIDTH/2.0, -CAVE_HEIGHT/2.0, 0])
cave = vizcave.Cave()
cave.addWall(PowerWall)
# creates a dummy-tracker (a group object is an empty node)
head_tracker = viz.addGroup( pos=[0, 0, -DISTANCE] )
cave.setTracker(head_tracker)
view = vizcave.CaveView(head_tracker)
cave.setIPD(0.06)
scene = vizfx.addChild('office.ive')
scene.hint(viz.ALLOW_NPOT_TEXTURE_HINT)  # allow for non-power of two textures
view.setPosition([1.659, 1.819, -2.280], viz.ABS_GLOBAL)
view.setEuler([-5.432, 1.980, 0], viz.ABS_GLOBAL)
vizact.onkeydown('q', viz.quit)
Old 02-26-2018, 09:47 AM
EDIT:
There is ghosting when using Vizard's scenes (e.g. the piazza) with the following settings:
scene = vizfx.addChild('piazza.osgb')
view.setPosition([4.659, 1.819, -1.280], viz.ABS_GLOBAL)
ghosting, vizcave
Four Wall Cave using two client cluster JB_HP_Viz Vizard 3 05-13-2016 03:26 AM
Updating a Postprocessing effect MissingAFew Vizard 2 05-07-2015 09:58 AM
anaglyph effect at front view of cave g.vannan Vizard 1 02-03-2015 05:29 AM
[New here] Cave joy navigation esuna114 Vizard 2 06-11-2010 04:36 PM
Flipped floor in a CAVE shivanangel Vizard 1 03-10-2010 10:12 AM
