Old 04-20-2017, 09:51 AM
Lily Lily is offline
Registered User
Viz. texure-how to do transparent
Hi,everyone
So I'm new to Vizard, 3d modeling. I recently encountered 2 problems,
1. I imported one room model which I created in Maya, one wall of the room is transparent just as glass. But when I imported into Worldviz, the wall just was black, what should I do to make the wall looks transparent in worldviz?
2. when I imported the room model into worldviz, it had no lights even I have added lights when I created the model in Maya, so when should I do to light the model?
Many thanks for your help!!
Old 04-29-2017, 01:38 AM
1) We're most familiar with the 3ds Max to Vizard workflow but I'll check to see if an artist has suggestions.
2) You can add lights to the model in Inspector:
  • Go to Create Light and select a light type to add a light
  • Select the gear icon associated with the light in the scenegraph pane
  • To move the light, enable translate or rotate mode using the buttons at the top of the window
  • Save the model out to the OSG format and load it in Vizard
Transparent textures seeing through each other lklab Vizard 2 11-22-2015 12:53 PM
Transparent png broblems TarkaDahl Vizard 4 08-01-2011 03:12 AM
3d Text with Transparent Borders vjosh Vizard 3 12-01-2004 10:50 AM
TRANSPARENT MASKS not transparent Vhihu Vizard 3 11-05-2004 02:11 PM
