Old 09-13-2016, 11:44 AM
dcnieho dcnieho is offline
passthrough fragment shader
I am trying to do a bit of vertex (and hopefully geometry) shading with the vertices of a node. Specifying a shader program with no fragment shader, or specifying the below fragment shader however both lead to color of the node being discarded.
obj = vizshape.addSphere()
shader = viz.addShader(vert=getVertexCode(),frag=None)
obj.apply(shader)
fragment shader instead of None above:
void main()
	gl_FragColor = gl_Color;
Could you let me know what the passthrough vertex shader should look like in this case?
multitex fragment shader issue for different sized textures pitbool Vizard 3 12-08-2015 07:22 PM
Texture Coordinate Generation (TexGen) using Shader goro Vizard 1 05-31-2013 01:44 AM
SSAO Shader Implementation FranciscoPeters Vizard 2 10-08-2011 04:19 AM
Specular Shader Issue shivanangel Vizard 2 05-06-2009 11:08 AM
