Old 03-12-2012, 09:20 AM
disbeat disbeat is offline
Error after vizard 4 installation
After installing vizard I've tried to run the following code:
viz.add('dojo.osgb')
but I get a blank image with the following error on the command line:
Warning:: Mipmapped osg::Image not a power of two, cannot apply to texture.
I've been using vizard for a long time and nothing like this ever hapened. May be an error with your latest build?
Best regards,
Marco Simões
Old 03-12-2012, 12:07 PM
Are you using the dojo model that comes with Vizard? It sounds like a texture in the model might be exceeding the maximum supported texture size of your graphics card. The largest texture in that model should by 2048x2048. Most cards these days should support that. What graphics card does the machine have and are the drivers up to date?
Old 03-12-2012, 12:33 PM
It was the graphic card drivers.
Thanks for the help!
-- Marco
Old 05-07-2016, 08:44 AM
frdarya frdarya is offline
Registered User
similar issue
Hi, I might be a little late for the party but - how did you manage to solve this issue?
I'm using
Darya
Old 05-07-2016, 11:20 PM
If you're getting the same error running the same example script, it's probably due to the graphics card or drivers.
Old 08-20-2016, 08:12 AM
leviz1 leviz1 is offline
Same error in vizard 5
Guess i'm also a little late to this thread but I have the same problem
Assuming the issue is indeed with the graphics card or drivers,
What can I do to resolve it?
Thank you,
Lana
Old 08-20-2016, 11:03 PM
You could try updating the graphics drivers. What kind of graphics card does the machine have?
Vizard software Installation blessonisaac Vizard 1 09-16-2010 04:02 PM
