Old 06-02-2015, 02:39 AM
mamort mamort is offline
Cluster Resource File Size
Hi All,
Just wondering if there is a limited to resource file sizes when running Vizard in a CAVE configuration.
Currently I am having a problem loading a 320mb FBX file in CAVE configuration as it appears to timeout before loading (it is in the resource folder on all computers within the cluster). I can load a 60mb FBX file fine on CAVE configuration.
The same 320mb FBX file loads fine on a single laptop so it appears to be an issue with the CAVE configuration.
Any suggestions?
Old 06-02-2015, 12:53 PM
Try increasing the value for the connect timeout in the cluster master.
Old 06-09-2015, 04:58 AM
thanks this worked I also had to increase the sync and frame timeouts.
cave
Unexpected Change of Window Size javadi Vizard 7 07-23-2013 02:56 PM
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 06:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 01:20 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
