Old 04-09-2015, 03:19 PM
MissingAFew MissingAFew is offline
Offset position of link/attached object
How do you change the relative offset of an attached object when using viz.link? Is this possible? setPosition doesn't work and there doesn't seem to be a set relative position function. Also need the rotation as well.
Old 04-09-2015, 07:18 PM
You can apply a postTrans or preTrans operation on the link.
Old 04-11-2015, 02:12 PM
Thanks, I already figured out what I needed to. However I am having a few issues implementing a FPS style control scheme where the change in mouse position rotates the player. Here's pastebin of relevant code:
http://pastebin.com/GDFTYf2d
This code is contained within my function UpdateView and gets updated with the following:
vizact.ontimer(0,UpdateView)
Now this code works, however, it is very jittery. It is not smooth at all. And if I only move the mouse a little bit, it wont cause the player to rotate. The way Im doing this feels very "hacky", but I'm not sure how else to do it. I haven't any example code for this kind of control scheme. Is there a better way to accomplish this? To me it seems like the UpdateView function is not being called every frame which is the cause of the jitteryness, but I am not entirely sure.
Old 04-13-2015, 06:15 PM
One of the built-in cameras from the vizcam library may set up the navigation style you would like:
import vizcam
vizcam.FlyNavigate(forward='w',backward='s',left='a',right='d')
#vizcam.WalkNavigate()
viz.addChild('piazza.osgb')
Problem with object position Ryvan Vizard 2 01-22-2015 02:01 PM
How to get real time position of a object which is connected to a haptic device Melody Vizard 4 09-15-2014 03:35 PM
Create object with position relative to user head, but cannot be obstructed by others Notch Vizard 2 03-03-2014 08:16 AM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 11:23 AM
