Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 04-17-2013, 09:26 AM
cgsong58 cgsong58 is offline
How to load *.jpgx file? (not jpg)
I have download the following pdf file and resouces:
"Vizard Teacher in a Book and Vizard free art resources"
It is very interesting for me to follow the example in Vizard Teacher in a Book.
Some examples require the image with jpg file format.
But I found that some provided images at free resource are jpgx file format (not jpg file format) so that I could not run some examples.
Please let me know how to load jpgx file format or how to convert jpgx format to jpg format.
Old 04-18-2013, 11:05 AM
Which examples did you have trouble running? Vizard should be able to load the .jpgx files included with Teacher in a Book. Those files can be referenced without the 'x' added to the extension in the script.
Old 04-21-2013, 10:34 PM
I think I have refer to files in correctly.
Balloon example (p19)
Even though I hace used 'art/balloon.IVEx'
I have the following error message:
File "<string>", line 11, in <module>
File "C:\WorldViz\Vizard1.py", line 10, in <module>
balloon = viz.add( 'art/balloon.IVEx' )
File "C:\Program Files (x86)\WorldViz\Vizard4\python\viz.py", line 9407, in add
raise ValueError, 'Unrecognized file extension: '+fileType
ValueError: Unrecognized file extension: IVEX
** Load Time: 0.08 seconds
Old 04-22-2013, 07:57 PM
Problem in loading *.jpgx file in art folder
Jeff,
I have run the texture example demo ("texture coordinates demo.py) but I couldn't have correct images, foliage.jpg, and pine needles.jpg.
My code is as follows:
viz.clearcolor([.3,.3,.3])
viz.mouse( viz.OFF )
viz.MainView.setPosition(0,0,-1.5)
#Add the texture quad and the texture to put on it.
quad = viz.addTexQuad()
textures = []
files = ['foliage.jpg','pine needles.jpg' ]
for i in range(len(files)):
texture = viz.addTexture( 'art/' + files[i] )
texture.wrap( viz.WRAP_S, viz.CLAMP_TO_EDGE )
texture.wrap( viz.WRAP_T, viz.CLAMP_TO_EDGE )
quad.texture( texture, '', i )
textures.append( texture )
#.... I have cut at this point
Old 04-22-2013, 02:20 PM
Although the model has a .ivex extension, load the model without the x in the script:
balloon = viz.add( 'art/balloon.ive' )
Old 04-30-2013, 11:33 PM
Fail to load 'art/balloon.ive' files.
Jeff,
I have run two WorldViz 4.0 (32bit version) on two PC with the same Windows 7. I have tested the same demo programs in page 19 in Vizard Teacher in a Book with two PCs.
But one of PC failed to load 'art/balloon.ivx' file but the other has no problem in loading files. Please let me know why this happen.
The code is as follows:
#Add an empty array for the balloons.
balloons = []
#Use a loop to add 3 balloons to the world.
for i in [-1,0,1]:
#Add a model.
balloon = viz.add( 'art/balloon.IVE' )
#Set the position of the balloon.
balloon.setPosition( i, 1.8, 3 )
#Append the balloon to our array.
balloons.append( balloon )
#Change each balloon's color.
balloons[ 0 ].color( viz.GREEN )
balloons[ 1 ].color( viz.RED )
balloons[ 2 ].color( viz.BLUE )
I have the following error messages:
** Loading p18.py
Loading File: art/balloon.IVE
** ERROR: Failed to load model: 'art/balloon.IVE'
** Load Time: 0.21 seconds
Old 10-16-2014, 01:52 PM
Rusol Ali Rusol Ali is offline
http://forum.worldviz.com/
when i tried to insert gif photo that have animation,the photo already inserted but
there is no any motion
is this right method to add animation photo?
is there any method to insert animation photo?please help me urgently.
Old 04-22-2013, 07:39 PM
Yes. Thanks, Jeff.
Old 04-22-2013, 08:52 PM
How to fix the error in link demo in Teacher in a book
I found that the link does make an error the following:
File "C:\WorldViz\teacher in a book demos and examples\teacher in a book code snippets (R4)\p44_example.py", line 46
head_bone = male.getBone( 'Bip01 Head' )
SyntaxError: invalid syntax
I know that viz.eyeheight(0) makes an error also.
My code in page 46 in Teacher in a Book is as follows:
#Link the view to the male's head.
view_link = viz.link( head_bone, viz.MainView )
#Set the eyeheight at 0 (so the default
#eyeheight is not added to the data).
viz.eyeheight( 0 )
Old 04-22-2013, 09:36 PM
I fixed the error.
Just before, I have fixed error.
Due to missing the right parenthesis in the previous statement.
Thanks.
Old 05-02-2013, 10:54 AM
Perhaps the file is missing or the script is not saved in the same folder so the relative path to the file is incorrect.
Old 10-14-2014, 04:29 PM
amahmud amahmud is offline
I also have the similar problem with executing the texture example demo ("texture coordinates demo.py), it loads the program but shows nothing because of that .jpgx extension, what could be the solution in this case?
Old 10-14-2014, 06:43 PM
You won't be able to open those files in an image editor but Vizard should be able to display them. Are you getting error messages when you run the script?
Old 10-16-2014, 06:42 PM
You could try converting the GIF file to a standard video format and then apply that as a video texture in Vizard.
Help with File Reading/Writing Lynnifer Vizard 2 03-12-2012 07:51 AM
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 07:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 02:20 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 03:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
