Old 07-09-2014, 08:29 AM
mshukun mshukun is offline
EXE doesn't create CSV file
I developed an application that creates a CSV file. The CSV file is created when I run the code through Vizard 5 IDE. However, after making the corresponding EXE file and running the same, the CSV file is no longer created. Is this problem occurring because of I am using the Vizard Beta version or due to something else? Thank you in advance.
Old 07-09-2014, 07:45 PM
Take a look at this thread.
Old 07-17-2014, 07:43 AM
Thank you so much. It worked perfectly. I created the application that also produce CSV file using Vizard 4.0 in the past. For that application, I used 'os.getcwd()' function and didn't have any problem producing a CSV file so I assumed it should work the same on Vizard 5 beta. I should have checked the Vizard module reference one more time before posting the question. Again, thank you so much for your quick response!!
input from a text file dig Vizard 5 10-20-2013 02:20 AM
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 07:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 02:20 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 03:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
