Old 08-04-2014, 07:35 AM
raj raj is offline
video restarting on right click in architectural interactive
hi
Need help on video restarting
currently working with architectural interactive application.
actually i have setup video texture on one 3d object
when i click on 3d object the video starts but when i click again in same object video stop and restart from begining
how can i prevent the video restarting from begining
or any 3d animation
plz reply
Old 08-04-2014, 03:11 PM
How would you like the behavior to be when you click on an already playing video? The options are pause, then resume, or stop then play from the beginning. Stop and play from the beginning is the default. If you want to modify this, you can do so by modifying the method onTriggerInteraction(self, e, hotspot=False): in the Interact.py module.
Old 08-08-2014, 12:09 AM
raj raj is offline
Thanks jeff
thanks for help
also click button on wand not working in cave mode(with sterio effect)with your example also
for example the oven door(animated door) in your kitchen example
i m trying to click to start animation with the wand trigger
but its not working..... is anything wrong with wand trigger????
the wand trigger only work with grab objects not with the click option.
regards
raj
Old 08-11-2014, 07:06 PM
I think the wand trigger should activate animations but I'll double check that with a developer. Is the top left button working to trigger the animations for you?
Old 08-21-2014, 02:39 AM
raj raj is offline
Thanks jeff
top left wand button working for animation.
regards
raj
synching video camera recording with vizard billjarrold Vizard 0 12-16-2009 12:43 AM
