Old 06-05-2014, 02:40 AM
jacky jacky is offline
Does OSGExporter for 3DS MAX2010 support "Super Spray" particle system?
Hi Everyone,
I'm creating a smoking model by using the "Super Spray" particle system in the 3DSMAX 2010. After exported this model to the .osg file and loaded it into Vizard, I found there's no smoke. Then I read the .osg file in the text editor and confirmed that the exported osg file didn't contain any information about particle. But exported .osg models created by using "spray" particle system worked well in the Vizard. I don't know if it's due to the parameters setting of the OSGExporter.
Does anybody know whether the OSGExport plug-in support the "Super Spray" particle system or not?
Jacky
Old 06-09-2014, 03:33 AM
From what I've heard, exporting particle effects using different methods is currently not supported or does not work well. In this thread, there is a link to some example particle effects:
http://forum.worldviz.com/showthread.php?t=3487
Moving / Rotating Particle Emitter, Not Entire System? shivanangel Vizard 2 02-15-2013 12:43 PM
