Old 02-27-2014, 11:29 AM
Stereo Setting Example Code
Just a script exposing stereo settings with slider bars.
import vizconfig
import vizdragdrop
import vizshape
viz.go(viz.FULLSCREEN | viz.QUAD_BUFFER) #to enable quad buffer, must be in the start
viz.MainWindow.stereo(viz.ANAGLYPHIC)
#viz.MainWindow.ipd(.06)
#viz.MainWindow.screenDistance(1)
#viz.MainWindow.fov(40)
#viz.MainWindow.fusionDistance(2.5)
#Create a configurable object for stereo settings
bc= vizconfig.BasicConfigurable('stereo')
bc.addChoiceRadioItem('Stereo Format',[('Quad buffer',viz.QUAD_BUFFER), \
										('Anaglyphic',viz.ANAGLYPHIC), \
										('Side by Side TV',viz.STEREO_3DTV_SIDE_BY_SIDE), \
										('Top Bottom TV',viz.STEREO_3DTV_TOP_AND_BOTTOM),\
										('Horizontal Stereo for 2 channels',viz.STEREO_HORZ)],\
										viz.MainWindow.stereo,viz.MainWindow.getStereo)
bc.addFloatRangeItem('Inter-pulilary Distance',[-.5,.5],fset=viz.MainWindow.ipd,fget=viz.MainWindow.getIPD)
bc.addFloatRangeItem('Screen Distance',[0,5],fset=viz.MainWindow.screenDistance,fget=viz.MainWindow.getScreenDistance)
bc.addFloatRangeItem('Field of View Vertical',[10,150],fset=viz.MainWindow.fov,fget=viz.MainWindow.getVerticalFOV)
bc.addFloatRangeItem('Fusion Distance',[.2,10],fset=viz.MainWindow.fusionDistance,fget=viz.MainWindow.getFusionDistance)
vizconfig.register(bc)
vizconfig.getConfigWindow().setWindowVisible(True)
gallery = viz.add('gallery.osgb')
f = viz.add('vcc_female.cfg', pos=[0, 0, 2])
f.state(5)
import vizcam
tracker = vizcam.addPivotNavigate()
tracker.setPosition([0,1.5,0])
viz.link(tracker,viz.MainView)
#load files dropped on me
vizdragdrop.enable()
dropedModel = None
def onDropModelFile(e):
	global dropedModel
	if dropedModel:
		dropedModel.remove()
		gallery.remove()
		f.remove()
		vizshape.addGrid()
	dropedModel = viz.add(e.filenames[0])
vizdragdrop.onDropFile(None,onDropModelFile)
Paul Elliott
WorldViz LLC
Problems with using WIRKS without the Kinect in a mirror setting Jennifer Vizard 0 06-03-2013 04:17 PM
stereo fusing trouble with caveview pitbool Vizard 1 10-16-2012 09:00 PM
what is causing (a) slow frame rate and (b) spontaneous NVIDIA stereo off billjarrold Vizard 0 07-11-2012 02:25 PM
vizcave and quad-buffered stereo michaelrepucci Vizard 7 11-29-2011 12:15 PM
walkto plays no animation... k_iwan Vizard 15 06-10-2008 11:04 AM
