Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 08-29-2013, 02:36 PM
williamchappell williamchappell is offline
Splitting a string into 3 ints, or getting x,y,z position
Hey, the project I'm currently working on requires me to store the players position in a text file, and then read the data back into the file to make a simulation of exactly what they did.
So far I can write the position in the file, and read it back out, however, when I read it out, I can only retrieve a string like "10,10,10" and need to split this into three floats, but nothing I'm doing seems to work.
Either this, or if I could get the x, y, z position of the player individually, that might be easier.
Thanks, Will.
Old 08-29-2013, 03:20 PM
Here's a code sample that shows how to parse the string "10,10,10" into a list of floating point numbers:
s = "10,10,10"
pos = [ float(x) for x in s.split(',') ]
print pos
Old 08-29-2013, 05:11 PM
Thank you so much! You're a life saver.
Old 08-30-2013, 08:32 AM
In the future, you might want to look at using the cPickle module for storing objects (lists, numbers, dictionaries, pretty much anything) in a text file and retrieving the same objects later on.
Here is an example where the rotation of the mainview of Vizard is stored in a text file (by pressing the d-key) and read from that file (by pressing the r-key):
import cPickle
def writeInfo():
	orientation = viz.MainView.getEuler()
	file_rot = open('MainView_rot.txt', 'w+')
	cPickle.dump(orientation, file_rot)
	file_rot.flush()
	file_rot.close()
	print 'Succesfully pickled:', orientation
def readInfo():
	try:
		file_rot = open('MainView_rot.txt', 'r')
		orientation = cPickle.load(file_rot)
		file_rot.flush()
		file_rot.close()
		print 'Succesfully unpickled:', orientation
	except IOError:
		print 'Could not read file!'
def onKeyDown(key):
	if key in 'dD':
		writeInfo()
	elif key in 'rR':
		readInfo()
		pass
viz.callback(viz.KEYDOWN_EVENT, onKeyDown)
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
String within a string problem? Elittdogg Vizard 1 08-29-2008 01:35 PM
