Old 03-14-2013, 05:26 PM
westbyb westbyb is offline
Temporal delay on movement
I was wondering if there was a way to delay the input sent for movement. I'm using vizcam.addWalkNavigate() to control my movement currently, and I was wondering if there was a way to have my movement be slightly delayed from my actual input, so that I can, for example, press the key to move forward and then a second or two later, the movement would actually occur.
Thanks in advance!
Old 03-15-2013, 07:49 AM
You could try something like the following:
import vizcam
DELAY = 2
dojo = viz.add('dojo.osgb')
walkNav = vizcam.addWalkNavigate()
recordedData = []
def RecordTrackingData():
	recordedData.append( (walkNav.getPosition(), walkNav.getQuat()) )
vizact.onupdate(0,RecordTrackingData)
def ApplyTrackingData():
	pos,ori = recordedData.pop(0)
	viz.MainView.setPosition([pos[0],1.8,pos[2]])
	viz.MainView.setQuat(ori)
ApplyDataCallback = vizact.onupdate(0,ApplyTrackingData)
ApplyDataCallback.setEnabled(viz.OFF)
vizact.ontimer2(DELAY,0,ApplyDataCallback.setEnabled,viz.ON)
Old 05-21-2013, 04:20 PM
Fantastic! That worked for using addWalkNavigate, but I'm now using VRPN 7 to get location data, as such:
vrpn = viz.add('vrpn7.dle')
headPos = vrpn.addTracker( 'PPT0@'+PPT_MACHINE,0)
iLabs = viz.addExtension( 'inertiallabs.dle' )
headOri = iLabs.addSensorBus(port=INERTIALLABS_HEAD_PORT)[0]
I've tried subbing these values into the code that worked previously, but it's seeming that won't be possible. How should I go about implementing the same idea using vrpn?
Old 05-21-2013, 06:46 PM
Are you getting any errors? Can you post the code you tested with?
Old 05-23-2013, 03:41 PM
No errors, but here's the code I'm working with:
viztracker.go()
recordedData = []
recordedData.append( (headPos.getPosition(), headOri.getQuat()) )
ApplyDataCallback.setEnabled(viz.OFF) #OFF
vizact.ontimer2(TIME_DELAY,0,ApplyDataCallback.set Enabled,viz.ON) #ON
I imagine that switching from viz.go() to viztracker.go() is what's causing the issue. I swapped viz.OFF/ON with viztracker.OFF/ON with no results.
Old 05-23-2013, 07:06 PM
The manual setting of the viewpoint in your script is overridden by the viewpoint link defined in the viztracker file. For this custom viewpoint movement its probably best to configure the trackers in this script and not use viztracker.
3ds Exported .IVE Model mirrors movement of Mainview Felix Vizard 9 05-18-2012 10:17 AM
Jerking Movement ssaha Vizard 0 04-08-2010 12:41 PM
Reading bone movement from animations Enlil Vizard 5 08-14-2008 03:29 PM
Mouse/Keyboard Movement joeymax Vizard 1 04-02-2007 11:43 AM
movement problems keastman Precision Position Tracker (PPT) 1 09-09-2003 12:41 PM
