Old 01-24-2013, 06:38 PM
Question Loading a 3D Texture
I couldn't find a ton of documentation in the help files on loading 3D textures.
I am interested in loading a series of 2D images into a 3D texture.
From what I read, the <multimedia:image>.load method should allow me to build a 3d texture.
I am trying to use a series of 2d pngs and turn them into a 3d texture for my shader to access. I have everything setup, the problem is when I try and use 'load' I get the following error:
** ERROR: 'BodyScans\FullBodyThresholded\002.png' cannot be loaded into depth 1 of 3D texture. Valid range is 0-0
I get this error for every image I load.
How do I setup the valid range for a texture? I tried making a 'blanktexture' and manually state I wanted a set number of depth images, but I still got the same error.
Here is my load method:
	def loadImages(self, dir):
		files = os.listdir(dir)
		for num, f in enumerate(files):
			if f[-3:] == 'png':
				print f
				if self.texture3D == None:
					self.texture3D = viz.addTexture(dir + f, type = viz.TEX_3D)
				self.texture3D.load(dir + f, face = num)
		self.texture3D.compression(viz.COMPRESSION_ARB)
		self.texture3D.hint(viz.PRELOAD_HINT)
George
Old 01-24-2013, 07:11 PM
You can use the viz.addBlankTexture command to create 3D textures with a specified depth. Here is a sample script showing how to load images into each depth slot:
#Create list of 2D images that will make up 3D texture
files = [ 'launch_stills/sts90launch'+ str(i+1) + '.jpg' for i in range(31) ]
#Create blank 3D texture
tex = viz.addBlankTexture([64,64,len(files)],viz.TEX_3D,minFilter=viz.LINEAR_MIPMAP_LINEAR)
#Load each image into 3D texture
for i,f in enumerate(files):
	tex.load(f,i)
#Apply texture to quad
quad = viz.addTexQuad(pos=(0,1.8,2),texture=tex)
#Create slider to change z texture coordinate of quad
slider = viz.addSlider(pos=(0.5,0.1,0))
def SetDepth(pos):
	m = viz.Matrix.translate(0,0,pos)
	quad.texmat(m)
vizact.onslider(slider,SetDepth)
viz.startlayer(viz.QUADS)
#Lower left
viz.texcoord(0,0,0)
viz.vertex(0.4,0.01,0)
#Upper left
viz.texcoord(1,0,0)
viz.vertex(0.4,0.05,0)
#Upper right
viz.texcoord(1,0,1)
viz.vertex(0.6,0.05,0)
#Lower right
viz.texcoord(0,0,1)
viz.vertex(0.6,0.01,0)
otf = viz.endlayer(parent=viz.SCREEN,texture=tex)
Hope this clears things up.
Old 01-25-2013, 10:27 AM
Question
#Edit - Still get the same problem on a Quadro 6000 with JPG or PNG
Unfortunately, I am still running into the same error, even when I copy and paste in your code.
I made a small subset of jpg images to see if there was a problem with the png format, and I still encounter the following error.
** ERROR: 'BodyScans/Test/3.jpg' cannot be loaded into depth 1 of 3D texture. Valid range is 0-0
** ERROR: 'BodyScans/Test/4.jpg' cannot be loaded into depth 2 of 3D texture. Valid range is 0-0
** ERROR: 'BodyScans/Test/5.jpg' cannot be loaded into depth 3 of 3D texture. Valid range is 0-0
** ERROR: 'BodyScans/Test/6.jpg' cannot be loaded into depth 4 of 3D texture. Valid range is 0-0
Do you happen to know what the error is exactly referring to for the 0-0 range?
I end up just having the first texture applied to the object.
I am developing on a laptop using an NVIDIA GTX 675M.
Are 3D Textures not be supported on these cards? Couldn't find any documentation only
I'll give it a shot on a Quadro in a few minutes.
Thank you,
George
Old 01-25-2013, 10:32 AM
Can you post the copy/pasted code you are running? Your original code sample was not using viz.addBlankTexture to create the 3D texture and specify the depth dimension.
Old 01-25-2013, 10:36 AM
I am now using your code and I still get the same error.
Only difference is I change the images being used to a different directory.
files = [ 'BodyScans/Test/'+ str(i+1) + '.jpg' for i in range(1,6) ]
tex = viz.addBlankTexture([512,512,len(files)],viz.TEX_3D, minFilter=viz.LINEAR_MIPMAP_LINEAR)
	tex.load(f,i)
def SetDepth(pos):
	quad.texmat(m)
#Lower left
viz.texcoord(0,0,0)
#Upper left
viz.texcoord(1,0,0)
#Upper right
viz.texcoord(1,0,1)
#Lower right
viz.texcoord(0,0,1)
Old 01-25-2013, 10:55 AM
What version of Vizard are you using? And to be clear, do you get any errors if you run the original script I posted, without any changes?
Old 01-25-2013, 11:13 AM
** Load Time: 1.59 seconds
** Loading VizardBodyPlanes.py
[512, 512, 5]
** Load Time: 0.15 seconds
Old 01-25-2013, 11:23 AM
I believe the issue is that the image dimensions of the files don't match the 3D image dimensions. Are all the files you are loading 512x512?
Old 01-25-2013, 11:31 AM
Attached are the image, they all look good to me.
Old 01-25-2013, 01:38 PM
Question
Sample of the actual images attached.
The errors spits out for every single one of the images when I try to load them.
~George
ID:	568   Click image for larger version
ID:	569   Click image for larger version
ID:	570   Click image for larger version
ID:	571   Click image for larger version
Old 01-25-2013, 02:33 PM
I just tried your sample images and they loaded fine. They are 100x100 though, but that might just be the forum resizing the images. The error message you are getting should only occur if the image your are loading does not match the 3D image width/height dimension, or if the pixel formats differ.
Old 01-25-2013, 02:43 PM
That is the forum resizing the images.
They all check out to be 512x512 inside Photoshop...
Old 01-25-2013, 02:53 PM
I just tried downloading the forum images and I get back the 512x512 for some reason... However I tried changing the last one to half the size to see what error I get... and it isn't a dimension error I seem to be getting on the other images.
I get a dimension error on the last one:
** ERROR: 'BodyScans/Test/3.png' cannot be loaded into depth 1 of 3D texture. Valid range is 0-0
** ERROR: 'BodyScans/Test/4.png' cannot be loaded into depth 2 of 3D texture. Valid range is 0-0
** ERROR: 'BodyScans/Test/5.png' cannot be loaded into depth 3 of 3D texture. Valid range is 0-0
** ERROR: Size of 'BodyScans/Test/6.png' (256 x 256) does not match size of 3D image (512 x 512)
Old 01-25-2013, 03:03 PM
OK, I just made some crappy images in Photoshop, all white jpgs with numbers and they appear to work properly.
Seems that something is wrong with the pngs, even though Photoshop and Matlab ( the original producer of the image) doesn't say anything is...
The images appear to be 8 bit on inspection as well.
Old 01-25-2013, 03:10 PM
Looks like all the images are grayscale only.
Converting to RGB fixes the problem.
Sorry to run you around on this problem!
viz.tex_3d
Avatar texture swaping sleiN13 Vizard 5 06-24-2011 12:48 AM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 12:12 PM
