Old 10-19-2012, 02:03 AM
Batigol Batigol is offline
get object on mouse click
Hi all,
I'm very new with Vizard.
I'm trying to get object on mouse click. But I just get to root object viz.VizChild(1) not the subobject like c1,c2....
The viz.pick(info=True).name just return the name of material not object name.
How could I access to subobject?
Old 10-22-2012, 03:21 PM
You can use the node.getChild command to get a handle to a sub-node. Example:
slider = viz.addChild('sodoku.ive')
c2 = slider.getChild('c2')
obj = viz.pick()
if obj == c2:
    print 'c2 picked'
Old 10-22-2012, 07:30 PM
I already tried it. It worked.
But it is so strange to compare with other game engine
Anyway, thanks for your comments
Old 10-25-2012, 01:14 AM
JvdBosch JvdBosch is offline
obj = viz.pick()
if obj == c2:
    print 'c2 picked'
This works fine, but introduces extra drawables in the scene. With large scenes this can hurt the framerate. Is there no other way to do this? Maybe it can be on the wish-list for the next update?
Old 10-25-2012, 09:36 AM
Calling getChild should not introduce more drawables. Can you post an example where it does?
This is already a feature in the upcoming Vizard 5 release. You will be able to get access to the full node hierarchy of the intersection.
Old 10-25-2012, 08:03 PM
It's sound great
Mouse bug in V3 and V4 Renato Lima Vizard 2 05-11-2011 06:38 PM
grabbing the object under mouse dwaik Vizard 2 03-02-2010 01:46 AM
how to pick up the object, move and rotate using mouse nasr Vizard 5 05-05-2009 03:11 AM
moving and object by mouse but don't know how to stop the movement nlfrnassimi Vizard 8 04-26-2009 07:23 AM
