Old 09-08-2012, 07:14 AM
mhead10 mhead10 is offline
Obj unable to find material ' '
I can't see to load my .obj model, and I know it worked previously in Vizard 3.0. I'm sure it's something silly and easily fixable.
The python file and .obj file are in the same folder, so I'm not sure why the .obj file cannot be found.
My troubleshooting code is quite simple:
temp = viz.add('temp_1.obj')
Thanks in advance!
Old 09-10-2012, 05:59 PM
What's the error message you are getting in Vizard? Can you attach the model to this thread or upload here for us to look at?
Old 09-11-2012, 07:10 AM
Jeff,
I receive the following error message when loading my temp_1.obj file with:
marker = viz.add('temp_1.obj')
Loading File: temp_1.obj
Obj unable to find material ''
Unfortunately the file will not attach here, but my uploaded reference code is 864102.
Thanks for your help!
Old 09-11-2012, 12:05 PM
The file loads and the geometry is there. The problem is that the scale is off and you don't see it. Try running the following:
viz.add('temp_1.obj',pos=[0,2,2],euler=[0,-90,0],scale=[0.01,0.01,0.01])
The error message indicates there are no associated material files found.
Old 09-11-2012, 01:13 PM
I've actually gotten the temp_1.obj file to load, from my code and yours, and I can see it, but I continue to get the same error (aka- it still says:
Obj unable to find material '').
Even though everything appears to be okay, I would still like to get rid of this glaring red error.
In response to your "The error message indicates there are no associated material files found." comment, is this just something that should have been included when the .obj was saved? I'm unclear exactly what association is missing.
Old 09-27-2012, 05:22 AM
Sometimes my .obj and .wrl files would load, and sometimes they would not. Therefore, to always get my 3d files to load (with their respective texture), I did the following to yield successful results:
http://www.javelin-tech.com/blog/201...w-to-sketchup/
.obj load correctly if they come from Google Sketchup (and not Solidworks directly)
1. Thus, save ACIS (.sat) in Solidworks
2. Next, download draftsight
3. In DraftSight’s command line type: “IMPORTSAT” and press <ENTER>. Locate the ACIS file you saved at step #1 and import it in DraftSight.
4. Save this file again in DWG format.
5. Open SketchUp
6. Import the DWG file you saved at STEP #4.
7. Save sketchup model as .dae
8. import into vizard using:
viz.add('name.dae',pos=[x,y,z],euler=[0,0,0],scale=[1,1,1])
Hopefully this will be helpful to others who do not have Blender.
dae, obj, sldprt, solidworks
Vizard and OBJ Material Files shivanangel Vizard 3 10-04-2013 07:11 AM
Realistic Glass Material EnvisMJ Vizard 1 10-21-2011 07:32 PM
How to convert VRay material into Vizard? hengshan.li Vizard 4 01-18-2011 10:14 AM
Cal3d material problem fracture Vizard 0 09-10-2009 02:58 AM
Unable to get material onto 3d Max avatar VDong Vizard 1 03-10-2009 12:45 PM
