Old 05-14-2012, 09:38 AM
yth yth is offline
Problem rendering on-the-fly objects
I'm experiencing strange effects when adding on-the-fly models to a scene using the vizshape module. When adding cylinders for example, the top and bottom of the cylinders are not closed, exposing various surfaces inside the cylinder and the reverse side of the cylinder can be seen through (see attachment). When creating a sphere, the result is a flat (2D) version of the sphere.
The described effects occur whenever such on-the-fly objects are added - e.g. when running the code from the tutorials. Other simulations run fine, such as the first tutorial showing the town square, plant models, avatars etc. Other OpenGL applications using 3D primitives seem to work fine, too. The problem occurs on a Lenovo Thinkpad R500 (which has a Mobile Intel 4 Express graphics card). Display drivers are up-to-date. My script runs fine on a second machine.
I'm not familiar with OpenGL, so I have no idea what could be causing these effects. What might be the problem here?
Yannick
Old 05-14-2012, 09:48 AM
We've had a lot of reports of strange issues and crashes with Intel drivers in the past. I wouldn't be surprised if this is another driver issue with Intel. What kind of graphics card does your second machine have?
Old 05-14-2012, 09:54 AM
yth yth is offline
The second machine has a nvidia card.
Font 3D rendering problem Renato Lima Vizard 3 10-07-2010 04:30 PM
Rendering problem in InfiniteTerrain omidbrb Vizard 2 02-24-2009 02:57 AM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 12:04 PM
Rendering problem Vygreif Vizard 1 05-01-2006 03:26 PM
Texture map rendering problem JRichizzle Vizard 4 03-04-2004 07:20 AM
