Old 06-06-2012, 12:35 PM
kovitch kovitch is offline
TexQuad FadeOut/FadeIn issue
I'm experiencing some kind of a problem, when using fadein/fadeout on viz.SCREEN. Despite the code I use there's no fadeOut. The image justa appears after 1 sec.
The code I use is:
    def drawTrainingList(self,prod_list):
        products_per_column = 8
        image_y_position = 0.75225
        image_x_position = 0.125
        background_x_inc = 0.125
        image_y_pos_inc = 0.097
        image_x_pos_inc = 0.3335
        number_x_pos_inc = 0.07
        number_y_pos_inc = 0.05
        text_x_pos_inc = 0.01
        text_y_pos_inc = 0.05
        if len(prod_list) < 9:
            image_x_position += image_x_pos_inc
        elif len(prod_list) > 8 and len(prod_list) < 17:
            image_x_position += image_x_pos_inc/2
        product_index = 0
        self.background_texture_list =  []
        self.product_texture_list = []
        self.product_text_list = []
        self.seq_numbers_list = []
        fadeOut = vizact.sequence( vizact.method.visible(1), vizact.fadeTo(1.0,speed=1.0) )
        self.background_wallpaper = viz.addTexQuad(viz.SCREEN,align=viz.TEXT_LEFT_BOTTOM,pos=(0,-0.1,0),scale=(12.8,11.725,1))
        self.background_wallpaper_texture = viz.add(config.SCREEN_PATH + 'background.png')
        self.background_wallpaper.texture(self.background_wallpaper_texture)
        self.title_text = viz.addText('Ingredients', parent = viz.SCREEN,align=viz.TEXT_CENTER_CENTER,pos=(0.5,0.92,0),scale=(0.85,1,1))
        while product_index < len(prod_list):
            if product_index % products_per_column == 0 and product_index != 0:
            self.background_texture_list.append(viz.addTexQuad(viz.SCREEN,align=viz.TEXT_LEFT_BOTTOM,pos=(image_x_position-background_x_inc,image_y_position,0)))
            self.background_texture_list[product_index].texture(prod_list[product_index].background)
            self.background_texture_list[product_index].setScale(4.275,1.0)
            self.background_texture_list[product_index].alpha(0)
            self.background_texture_list[product_index].visible(0)
            self.product_texture_list.append(viz.addTexQuad(viz.SCREEN,align=viz.TEXT_RIGHT_BOTTOM,pos=(image_x_position,image_y_position,0)))
            self.product_texture_list[product_index].texture(prod_list[product_index].texture)
            self.product_texture_list[product_index].setScale(0.775,1.0)
            self.product_texture_list[product_index].alpha(0)
            self.product_texture_list[product_index].visible(0)
            self.product_text_list.append(viz.addText(prod_list[product_index].name,viz.SCREEN,align=viz.TEXT_LEFT_CENTER,pos=(image_x_position+text_x_pos_inc,image_y_position+text_y_pos_inc,0),scale=[0.35,0.4,0.4]))
            self.product_text_list[product_index].alpha(0)
            self.product_text_list[product_index].visible(0)
            self.seq_numbers_list.append(viz.addText(str(product_index+1)+'.',viz.SCREEN,align=viz.TEXT_RIGHT_CENTER,pos=(image_x_position-number_x_pos_inc,image_y_position+number_y_pos_inc,0)))
            self.seq_numbers_list[product_index].alpha(0)
            self.seq_numbers_list[product_index].visible(0)
            self.seq_numbers_list[product_index].setScale(0.3,0.4)
            self.background_texture_list[product_index].runAction(fadeOut)
            self.product_texture_list[product_index].runAction(fadeOut)
            self.product_text_list[product_index].runAction(fadeOut)
            self.seq_numbers_list[product_index].runAction(fadeOut)
            image_y_position -= image_y_pos_inc
            product_index += 1
            yield viz.waittime(config.DRAW_LIST_ELEMENT_INTERVAL)
What is the problem with the desired effect? Am I missing something?
I've arealdy tried something like this to 3d models and everything runs smoothly.
Best regars,
Alex.
Old 06-06-2012, 03:51 PM
What is the value of the config.DRAW_LIST_ELEMENT_INTERVAL variable? You are passing this value to viz.waittime, which will block rendering for the specified amount of seconds. If the value of the variable is around 1 second, then you are stalling the frame for a second and it when it continues, the fade action will be complete.
I noticed you are yielding the value of viz.waittime. Were you intending to use viztask.waitTime instead?
Old 06-07-2012, 01:25 PM
You're totaly right i wanted to use viztask instead, my bad. Thanks!
Using a texquad to cover a window Enlil Vizard 4 02-07-2012 04:13 PM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 11:44 AM
Cal3D texture issue from Max shivanangel Vizard 5 10-17-2008 01:17 PM
vizard 2.5 compatability issue shai Vizard 3 08-10-2005 05:35 PM
texquad shai Vizard 1 02-23-2005 02:09 PM
