Old 04-11-2012, 03:27 PM
Salvar Salvar is offline
Turning a path into a wireframe
Hi.
I'm currently trying to turn a set of coordinates that form a curved line into a wireframe of a road where these coordinates define the middle of the street.
The simplest I've come up with is using the coordinates to draw a very thick line (via viz.LINE_STRIP and viz.linewidth) and setting the polygon mode to POLY_WIRE, but it comes out as a filled line with very jaggy edges.
Any ideas? I'm probably missing something obvious here.
Thanks.
Old 04-13-2012, 08:27 AM
Have you tried enabling anti-aliasing?
http://kb.worldviz.com/articles/831
Old 04-13-2012, 09:46 AM
I have not. Thanks, I'll try that. But that still leaves the issue of POLY_WIRE giving me a filled area. Does this only apply to polygon shapes, and not lines?
Old 04-14-2012, 06:35 AM
Yes, that applies to polygons. You'll have to create two parallel line strips with smaller widths.
Old 04-17-2012, 05:25 PM
All right, thanks for the help.
Array, concatenate, multiple path help please sircedric4 Vizard 3 10-28-2009 05:14 AM
Start_position on animation path ptjt255 Vizard 1 08-24-2009 11:40 AM
smoothing a cubic bezier path just alex Vizard 10 04-22-2009 01:07 PM
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 04:23 PM
speed on animation path whj Vizard 8 11-17-2008 07:41 PM
