Old 03-28-2012, 10:08 PM
allanjjj allanjjj is offline
Unhappy Vizard AR Problem.....
i saw the code below is to display avatar only when the marker is shown, but when I run the script, the avatar still shows and jump randomly if no marker is shown in Camera. Is there any problem with the code below?
#Add ARToolkit extension
ar = viz.add('artoolkit.dle')
#Create camera using first available webcam
camera = ar.addWebCamera()
#Create matrix marker
marker = camera.addMatrixMarker(0,width=1000)
#Add avatar model and set state 1
avatar = viz.add('vcc_male.cfg')
avatar.state(1)
#Link avatar model to marker sensor
viz.link(marker,avatar)
#Method that update if the marker is visible
def updateVisible():
if marker.getVisible():
avatar.visible(viz.ON)
avatar.visible(viz.OFF)
vizact.ontimer(0,updateVisible)
Old 03-30-2012, 09:16 AM
How long is the marker out of view, a fraction of a second or several seconds? Are other markers in view? The code looks fine but you may have problems if the marker flashes in and out of view or if something else is seen as a marker.
artoolkit
Vizard problem mizutani_jun Vizard 4 01-09-2011 04:39 PM
newbie problem getting vizard to work Colin Vizard 2 11-10-2006 11:54 AM
problem talking to usb device in Vizard Vbents Plug-in development 2 06-15-2006 04:08 PM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 11:52 AM
