Old 08-05-2011, 06:21 PM
hengshan.li hengshan.li is offline
The problem of adding two .ive models
I made two models by 3DS Max (baked the texture) and then converted them into .ive using OSGExporter v0.9.8.
When I added the two models in vizard, I met a problem. If I first add model A, A is OK, but B model does not load well (it failed to load the right UVW file).
If I first add model B, then B is OK, but model A is loaded wrong. If I only add model A or model B, both are right.
The two model contain the same name of baked tga file. For example, the floor object in model A and model B both use the "floorcompletemap.tga", but the file is at different file folder. I will check this problem and then update the thread.
Does anyone else have the same problem? Thanks.
Old 08-08-2011, 12:04 AM
sleiN13 sleiN13 is offline
You could try to bake the .tga files into the .ive that way you can be sure that both object point to their texture file.
Just check the "include image data in binary ive"-box during export.
I've been using multiple models with the same textures baked into them for some time with out a problem.
Problem with importing Quake2/md2 models johanzebin Vizard 3 09-05-2013 01:02 AM
Self illumination of .ive 3D models flip321 Vizard 0 11-13-2010 03:28 AM
Collision problem Dave Vizard 2 09-16-2010 04:25 AM
Problem on adding OSG file felixchc Vizard 4 10-06-2006 11:26 AM
