Old 04-02-2011, 10:20 AM
Zhi Zhi is offline
Is there an equivlent data type as the "struct" in C
Hi
I want to create a "struct" type variable array in Vizard. Each element in the array contains 5 sub-elements with different data type (i.e. string, int, float, etc.). Any suggestion? Thanks
Zhi
Old 04-02-2011, 02:38 PM
Zhi Zhi is offline
I checked the Python website. It seems a similar structure to the "struct" in C would be the "list" or "dict". The "list" is more like an array in C, while the "dict" is similar to the "struct". However, I don't know how to combine the list and dict to make a struct array. Can anyone help me?
Zhi
Old 04-02-2011, 02:56 PM
It sounds like you just want an array of custom class objects. The following code shows how to create a simple class and add instances of it to a list:
class MyStruct(object):
    def __init__(self,my_int,my_float,my_string):
        self.my_int = my_int
        self.my_float = my_float
        self.my_string = my_string
array = []
array.append( MyStruct(0,0.0,'foo') )
array.append( MyStruct(1,1.0,'bar') )
print array[0].my_string
Let me know if this isn't what you are looking for.
Old 04-02-2011, 04:40 PM
Zhi Zhi is offline
That's exactly what I want. Thank you.
Zhi
data lose psykoko Vizard 3 12-16-2010 09:08 PM
Use saved text file data as replay sources problem mizutani_jun Vizard 4 10-14-2010 05:49 PM
Using 5DT plug-in with the data coming through network... mcicek Vizard 1 05-18-2009 06:17 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 12:40 PM
tracking using quaternarion data jfreeman Vizard 2 06-01-2005 09:48 AM
