Old 04-02-2011, 08:47 AM
Zhi Zhi is offline
How to delay time in Vizard
Hi all,
I want to define a function which will be called when the mouse is clicked. The function will block the viz.MainView for a second. Here is my code:
import time
def BlockMainView():
viz.visible(viz.OFF)
time.delay(1)
viz.visible(viz.ON)
vizact.onmousedown(viz.MOUSEBUTTON_LEFT, BlockMainView)
However, the delay function seems being executed before viz.visible(viz.OFF) and viz.visible(viz.ON), so that the viz.visible(viz.OFF) seems never being executed. How can I solve the problem?
Zhi
Old 04-02-2011, 02:43 PM
Zhi Zhi is offline
I have found a way around:
def myTask():
while True:
btn = yield viztask.waitMouseDown(None) #Wait for mouse click
viz.visible(viz.OFF) #Turn off the screen
if btn.button == 1: #Left botton click
yield function_a()
elif btn.button == 4: #Right botton click
yield function_b()
yield viztask.waitTime(1)
viz.visible(viz.ON) #Turn on the screen
viztask.schedule(myTask)
Cheers!
Zhi
timer question Elittdogg Vizard 5 10-10-2007 03:49 PM
