Old 01-28-2011, 09:22 AM
pcatalano pcatalano is offline
Question Automatically set Cluster Master Settings
We are using Vizard in a small cluster/cave setup. Is it possible to set the Vizard Cluster Master settings in code or in a config? It can be tedious to have to enable the clients from the list (or change other options like port, synchronize, etc.) every time I log in. It looks like there are some options to do this using setoption but they don't seem to work for me.
Old 01-28-2011, 09:51 AM
You can use the viz.cluster.master.* settings to setup a cluster without using the cluster master application. However, you must specify these settings in you vizcore.cfg file. Since clustering needs to be initialized before your script is executed, using viz.setOption will not work with these settings.
The vizcore.cfg file can either be placed in the Vizard/bin folder, where it will be used by all scripts that are executed on your machine. Alternatively, you can place it in the same directory as your script, but it will only be used by scripts that are executed from that same directory.
Old 01-28-2011, 02:09 PM
Smile Worked, thanks!
Of course, that make sense. Thanks, worked like a charm!
Question about GUI and CLUSTER mizutani_jun Vizard 2 01-02-2011 04:35 PM
Full Screen automatically goes back to window mode vijaykiran Vizard 1 09-02-2009 03:19 PM
How to run Demo exe on 3 channel cluster Azlan.Vrs Vizard 3 04-27-2009 12:06 PM
Cluster Help videcuk Vizard 12 09-21-2007 03:14 PM
quad_buffer cluster John P Vizard 4 06-07-2006 11:01 PM
