Old 02-26-2016, 01:41 AM
Novakin Novakin is offline
Pass vertex array instead of calling viz.vertex()?
At the moment I use a lot of viz.vertex() calls to create a big model. This is slower than using pre-made models and using viz.add(), but I can't use that in my situation at the moment unfortunately.
My question. Instead of doing something like this:
call viz.startLayer() 1 time
call viz.vertex() a 100 times
call viz.endLayer() 1 time
is it possible to simply pass an array or list with vertices? So something like:
call viz.vertexArray() 1 time
I'm hoping to get a performance boost by not having to have Vizard do the IPC call a large number of times, and thereby reduce my startup time.
Old 02-26-2016, 09:11 AM
There is no command for this. Are the vertices different each time you run the application?
Old 03-01-2016, 12:06 AM
The problem isn't so much that the vertices are different each time, it's that the application doesn't know the positions beforehand, it's dependent on external data unfortunately.
Too bad there's no array-like command, but thank you for your answer nonetheless.
