Old 07-16-2010, 07:10 AM
sleiN13 sleiN13 is offline
Not drawing invisible objects
I've created a Vizard virtual world that stretches the hardware power to it's maximum because of this I've been looking at optimizations. One would be to reduce the polygons that need to be draw. Therefore I started to look at which area's had the most polygons and I noticed that Vizard also counts/draws polygons that are hidden by other objects.
Is there a way to tell vizard to not draw object that are hidden behind other objects in the world?
Old 07-19-2010, 04:45 PM
masaki masaki is offline
There isn't a built in Vizard function for occlusion tests - you would have to manually do this, but performing this test will also increase the load on your cpu, especially if you're doing it every frame.
Best,
Masaki
Old 07-19-2010, 11:55 PM
Just to state the problem the otherway around, How can vizard handle large outstretched worlds or a building with multiple rooms?
Old 07-26-2010, 01:07 PM
Though Vizard does not currently have a way of automatically doing occlusion culling, Occluders can be added manually within 3ds max using rectangular splines and the OSG Occluder helper. (Helpers --> OpenSceneGraph --> Occluder)
-For a large world, one option is to use fog + distance culling.
-Another option is to use the OSG Level of Detail helper. With this one, you would merge or group all the objects in a room and add it to the LOD helper, then set the distance in meters for that object to be visible. (Helpers --> OpenSceneGraph --> LOD)
Old 07-27-2010, 01:10 AM
I will have to look into those functions then. Thanks for the tips. Are there any plans for vizard to include these functionalities in future versions?
Old 07-27-2010, 12:54 PM
We are always working towards improving our graphical capabilities, so this function may show up in a later version.
Old 11-23-2010, 10:27 AM
Chapre Chapre is offline
Woderfull, I think I will use these occluders property too!
Invisible haptic objects Haptiken Vizard 1 05-05-2009 05:04 PM
Lightwave objects rotation problem hosier Vizard 6 02-13-2009 01:04 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 06:19 PM
