Old 11-10-2010, 10:03 AM
jassel41 jassel41 is offline
Lighting for a new Scene
Can anyone help me set up the lighting for a different scene number? Below is what I have originially.
viz.disable(viz.LIGHTING)		# Disables the lighting of the world
viz.collision(viz.ON)
viz.phys.enable() 				# Needed to catch collision events
# Adding object
obj = viz.add(object, viz.WORLD);
obj2 = viz.add(object, viz.WORLD);
headLight = viz.MainView.getHeadLight()
mylight = viz.addLight(viz.WORLD)
mylight.enable()
mylight.position(0, 100, 0)
mylight.intensity(0.85)
The above code runs fine and the lighting is right, but if I make it so obj and obj 2 get added to scene 2, then they show up dark. I tried putting mylight in scene 2, but no change.
Any suggestions?
Thank you in advance,
Jassel41
Old 11-10-2010, 07:11 PM
Try adding another light to scene 2.
Old 11-10-2010, 09:14 PM
I tried that, any other thoughts on why I can't get it to light correctly in scene 2? This is what I tried:
viz.disable(viz.LIGHTING, 2)		# Disables the lighting of the world
# Adding object
obj = viz.add(object, viz.WORLD, 2);
obj2 = viz.add(object, viz.WORLD, 2);
mylight = viz.addLight(viz.WORLD, 2)
mylight.enable()
Is there any other way to approach setting up the lighting?
basic lighting question malte Vizard 6 12-01-2010 12:25 PM
Warping Rendered Scene? rwgray Vizard 3 03-25-2010 02:19 PM
Copying Scene? Brett Lindberg Vizard 0 08-28-2009 11:56 PM
lighting issue cantwelljm Vizard 3 02-18-2006 08:21 AM
Vizard 2.0x lighting FlyingWren Vizard 4 08-11-2003 12:20 PM
