Old 10-06-2010, 04:27 AM
alberto_redo alberto_redo is offline
How can i import the code form a Java program to Vizard?
Hi, I am a student from Spain and I have a program written in java, this program was written by other person and I need to import this program to Vizard, I have found all the extensions that Vizard supports (WRL, OSG, 3DS...) but I canīt find any way to convert the Java code to any of this file extensions and I want know if anyone knows anything about this Thanks
Old 10-07-2010, 12:18 PM
Vizard uses the Python programming language for scripting. This means you will need to manually convert the Java program to Python. Depending on the size of the Java program, this can be a time consuming task.
How to import the defaultdict into vizard knightgba Vizard 3 07-26-2010 01:35 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 04:30 PM
vizard and java -> jython? Johannes Vizard 10 06-28-2005 10:23 AM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 10:52 AM
