Old 08-03-2010, 02:39 PM
Deltcho Deltcho is offline
Unhappy Problems exporting with Cal3D
I'm having problems exporting the mesh files using the Cal3D exporter from your website and 3ds max 2010 (32 bit). I am trying to export slightly modified versions of the complete characters set that we have.
Here's what I'm doing, please let me know if you know where the problem is:
1) I select the skeleton, then click "export" from the menu and select the Cal3D skeleton file, *.CSF. Skeleton exports fine.
2) I select the mesh, then click "export" from the menu and select the Cal3D mesh file, *.CMF. Then I pick the previously exported skeleton file when it asks for one during "Step 1", then click "Next". During step 2 I leave everything on default and click "Next", but it says "No meshes were selected for export" and gives an error (code 118).
When that didn't work, I tried selecting the entire mesh + skeleton and repeating Step 2). That exported a 1 KB CMF file which did not actually contain the mesh.
Any idea what the problem could be?
Thanks!
Old 08-03-2010, 03:27 PM
I figured out the problem.
Apparently when I switched the models over to the 2010 version, the Skin envelop modifier was removed. I just added it and things are exporting fine now.
Problem exporting to Cal3d from Max 8 dropshadow79 Vizard 3 01-13-2010 11:16 AM
Successful Cal3D Export But Texture Problems ezanih Plug-in development 2 01-26-2009 04:28 PM
Incampatible CAL3D files luakt Vizard 4 09-14-2008 11:28 PM
Exporting to .cfg using Cal3D marcoleon Vizard 6 06-27-2005 11:13 AM
cal3d Problems oscar Vizard 1 12-03-2004 10:18 AM
