Old 02-09-2012, 07:45 AM
amaze12 amaze12 is offline
I want to ask some program about vizard and 5DT
Now I have Vizard and 5DT dataglove, and i have read the ''5DT data glove basics''. But I want to make the virtual hand moves with sevral seconds dalay, not synchronous with my real hand.
Can someone help me? Thanks.
Best regards.
Old 02-16-2012, 12:04 AM
? No one care?
Old 02-16-2012, 06:16 PM
This should be possible. You would have to look in hand.py to see how 5dt sensor data is mapped to the hand model. You would have to customize that to account for a delay.
Old 02-19-2012, 02:49 AM
OK. Thanks. And what should I do if I want to calibrate the data glove?
Old 02-19-2012, 03:31 AM
I want to use vizard(python) to show the data. But why it cannot? The code is here.
import hand
PORT_5DT_USB = 0
glove = viz.add('5dt.dls')
data = glove.getData()
print data
But the data printed is only one line
[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
What should I do?
Old 02-19-2012, 01:29 PM
OK. Now I have solved the third question myself. So what should I do with the calibration?
Old 03-15-2012, 08:01 PM
Darkmax Darkmax is offline
normally with my glove i don't have to calibrate it, i just connect it and it works, maybe in some case i get a strange behavior but i just close and open the hand several times but that's all.
Old 01-08-2013, 06:08 AM
ann olegovna ann olegovna is offline
how did you print the data out?
5dt dataglove
