Old 03-14-2010, 08:26 PM
hahaho hahaho is offline
sensors confused
I want to use the sensor of the three.
these sensors want to fixed number[A,B,C], (no value[x,y,z])
for example)
sensorA(fixed number) = (10,10,10) <-x,y,z (receive(change) value)
sensorB(fixed number) = (20,20,20) <-x,y,z (receive(change) value)
sensorC(fixed number) = (30,30,30) <-x,y,z (receive(change) value)
so, i am used this code.
vrpn = viz.add('vrpn7.dle')
sensorA = vrpn.addTracker('PPT0@166.104.29.228',0)
sensorB = vrpn.addTracker('PPT0@166.104.29.228',1)
sensorC = vrpn.addTracker('PPT0@166.104.29.228',2)
def update():
      position1 = sensorA.getPosition()
      position2 = sensorB.getPosition()
      position3 = sensorC.getPosition()
      a =  position1[0]
      a1 = position1[1]
      a2 = position1[2]
      b = position2[0]
      b1 = position2[1]
      b2 = position2[2]
      c = position3[0]
      c1 = position3[1]
      c2 = position3[2]
      A = [a,0,a2]
      B = [b,0,b2]
      C = [c,0,c2]
      # vector
      v1 = vizmat.VectorToPoint(A,B)
      v2 = vizmat.VectorToPoint(A,C)
      v = vizmat.AngleBetweenVector(v1,v2)
      Forearm.setEuler([0,0,-v])
      UpperArm.setEuler([0, -30, -80])
      print v
vizact.ontimer(0,update)
but , the sensor's number is frequently change.
for example)
sensorB = (10,10,10)
sensorA = (20,20,20)
sensorC = (30,30,30)
sensorC = (10,10,10)
sensorB = (30,30,30)
How do i receive the fixed sensor's number?
Old 03-15-2010, 08:42 AM
mspusch mspusch is offline
If you are using marker-ID markers, you should contact support@worldviz.com about this, if there is marker swapping.
if you use non-marker-ID markers, then you should have a look here for algorithsm that help to distinguish which marker is which for a 2-hands / head setup:
http://forum.worldviz.com/showthread.php?t=175
Old 03-15-2010, 05:17 PM
If you are using non-marker ID markers another way of ditinguishing head and hands is to use the Mocap post-process plug-in within PPT Studio.
Problem of hand model(using sensors). atamasan Vizard 0 08-18-2009 11:33 PM
Sensor gets confused durf Precision Position Tracker (PPT) 1 04-23-2009 01:41 PM
Checking 2 sensors distance from each other durf Vizard 1 03-10-2009 01:52 PM
Using link to create offsets between sensors Enlil Vizard 2 08-28-2008 12:28 PM
cameras get confused by many LEDs tavaksai Precision Position Tracker (PPT) 9 05-19-2007 05:52 PM
