Old 03-26-2010, 08:01 AM
CRI CRI is offline
Vizard AR problem
When I make a video later showed
I then removed Marker
Shows the image will not disappear
Old 03-26-2010, 10:29 AM
Darkmax Darkmax is offline
I'm not exactly understand what you are referring but if you want to something disappear when the marker is not shown you have do something like this:
#Add ARToolkit extension
ar = viz.add('artoolkit.dle')
#Create camera using first available webcam
camera = ar.addWebCamera()
#Create matrix marker
marker = camera.addMatrixMarker(0,width=1000)
#Add avatar model and set state 1
avatar = viz.add('vcc_male.cfg')
avatar.state(1)
#Link avatar model to marker sensor
viz.link(marker,avatar)
#Method that update if the marker is visible
def updateVisible():
	if marker.getVisible():
		avatar.visible(viz.ON)
		avatar.visible(viz.OFF)
vizact.ontimer(0,updateVisible)
I hope is that what you need
Old 03-26-2010, 11:32 PM
CRI CRI is offline
I solved this problem
thank you!
Big problem with OpenSG exporter for max to Vizard omadawn Vizard 5 06-09-2009 12:51 PM
newbie problem getting vizard to work Colin Vizard 2 11-10-2006 11:54 AM
problem talking to usb device in Vizard Vbents Plug-in development 2 06-15-2006 04:08 PM
Vizard Crashes: causes are hard to determine, possible problem with the viz code vr_boyko Vizard 1 01-07-2005 11:52 AM
