Old 03-10-2010, 10:33 AM
Exclamation Flipped floor in a CAVE
Hello again ,
I am running Vizard on a 4 wall CAVE system at Rowan University.
I have read your CAVE file and have tried to create one of our own
for us to use with a Left, Right, Front and Bottom setup.
However, I consistently run into an issue where the bottom node seems
to be flipped. We are also running a PPT tracking system and an Inertia
Cube 3 wireless sensor.
I have setup the CAVE's center to be the literal center of the CAVE (height, width /2)
import vizcave
import viztracker
import math
import VectorHelper
def CaveInit():
	#Center is always assumed to be the red box on
	#the floor of the CAVE (wallpaper)
	#Use the PPT Tracker Offset command to fix
	#where the true center is if adjustments are needed...
	#Y Height should always be positive
	#CAVE Dimensions in Meters
	CAVE_W	= 3.048
	CAVE_H	= 2.286
	#Half Cave Dimensions
	CAVE_W2 	= CAVE_W / 2.0	# Half width
	CAVE_H2		= CAVE_H / 2.0	# Half height
	#CAVE Vertices
	# c0   c1   c2   c3
	# | L  |  F |  R |
	# c4 c5|  B |c6 c7
	#      b4  b7
	C0 = -CAVE_W2,CAVE_H,-CAVE_W2
	C1 = -CAVE_W2,CAVE_H,CAVE_W2
	C2 = CAVE_W2,CAVE_H,CAVE_W2
	C3 = CAVE_W2,CAVE_H,-CAVE_W2
	C4 = -CAVE_W2,0,-CAVE_W2
	C5 = -CAVE_W2,0,CAVE_W2
	C6 = CAVE_W2,0,CAVE_W2
	C7 = CAVE_W2,0,-CAVE_W2
        #CAVE FLOOR OFFSET DUE TO THE DEPTH NOT EQUALING THE WIDTH
	OFFSET = 0.762
	B4 = -CAVE_W2, 0, -CAVE_W2 + OFFSET
	B7 = CAVE_W2, 0, -CAVE_W2 + OFFSET
	# Create front wall
	FrontWall = vizcave.Wall(	upperLeft=C1,
								upperRight=C2,
								lowerLeft=C5,
								lowerRight=C6,
								name='Front Wall' )
	# Create left wall
	LeftWall = vizcave.Wall(	upperLeft=C0,
								upperRight=C1,
								lowerLeft=C4,
								lowerRight=C5,
								name='Left Wall' )
	# Create right wall
	RightWall = vizcave.Wall(	upperLeft=C2,
								upperRight=C3,
								lowerLeft=C6,
								lowerRight=C7,
								name='Right Wall' )
	# Create bottom wall
	BottomWall = vizcave.Wall(	upperLeft=C5,
								upperRight=C6,
								lowerLeft=B4,
								lowerRight=B7,
								name='Bottom Wall' )
	# Create cave object
	cave = vizcave.Cave()
	#cave.setIPD(0.06)
	#cave.setNearPlane(0.15)
	cave.setFarPlane(1000.0)
	viz.eyeheight(0)
	# Add walls to cave
	cave.addWall(FrontWall, mask=viz.MASTER)
	cave.addWall(LeftWall, mask=viz.CLIENT1)
	cave.addWall(FrontWall, mask=viz.CLIENT2)
	cave.addWall(BottomWall, mask=viz.CLIENT3)
	cave.addWall(RightWall, mask=viz.CLIENT4)
	return cave
I don't know if it is not proper to set the center of the CAVE as my origin.
The PPT system is set up "close" to that (not perfectly, but around head height) and a + Z-offset.
Thank you for any help you can give and I hope
you can help reduce my eye-strain from the bottom flipped node!
This seems to happen from time to time and it is annoying as all heck!
~George
Old 03-10-2010, 11:12 AM
Are you passing the raw ppt tracker object to the cave.setTracker function? Can you print out the PPT coordinates when the bottom view is flipped? Usually when a cave wall flips, it means that the users reported head position is behind the screen. This could be caused by a mis-configured cave or a problem with the tracking system.
orthographic projection in a head-tracked cave environment michaelrepucci Vizard 5 12-14-2011 11:29 AM
CAVE, navigation, tracked wand, coordinate systems JimC Vizard 6 10-09-2009 01:43 PM
right-hand to left-hand coordinate System for a cave setup Andy Vizard 1 09-16-2009 11:17 AM
Wiimote in 4 sided Cave Sjaak Vizard 2 05-20-2009 02:05 PM
Four Wall Cave on One Computer envisC Vizard 1 04-28-2009 06:02 PM
