Old 05-11-2007, 10:01 AM
asfammlab asfammlab is offline
Vizard plugin for 3DSMax 8
We can't install the Vizard plugin for 3DSMax 8 in Windows 64 bit. Is there any solution to this?
Thanks in advance
Old 05-11-2007, 10:04 AM
What exactly is the problem? Does the installer fail to locate your 3dsmax installation? Or, does 3dsmax fail to load the vizard plugin?
Old 05-14-2007, 10:11 AM
Hello!
Our problem is that although it seems that the setup is done successfully, the plugin does not appear in the Export option of 3DS Max 8.
Thanks a lot
Old 05-15-2007, 09:54 AM
The plugin was compiled on a 32-bit system, so it is probably incompatible with a 64-bit system. I'm not sure when we would be able to create a 64-bit version of the plugin.
