Old 10-26-2009, 11:55 PM
jincheker jincheker is offline
Whitespace as the default indentation
Can I use space as the default indentation in vizard?
Old 10-27-2009, 12:28 PM
No, this option is not currently available.
Old 10-27-2009, 08:38 PM
Or can I replace the whitespace indentation with tab? because some of my old code is done by using whitespace. Is there some software that can do this?
Old 10-28-2009, 12:16 AM
IGoudt IGoudt is offline
Python can behave annoying sometimes when it comes to mixed indentation with tabs and spaces. Especially in the Vizard environment this can be stressing, I have 2 solutions for this:
1: Use Eclipse (or another IDE tool) to create your code and then run the code with vizard. (If you use the search you can check how to use Vizard inside Eclipse)
2: copy the code with the wrong indentation to notepad, there you can remove all the tabs and whitespaces, then copy the plaintext to the vizard IDE and all the indentation should be gone so you can rebuild it properly
Old 10-29-2009, 09:18 AM
Thank you very much
Old 10-30-2009, 12:50 PM
You can replace all the the indentation with tabs in the Vizard GUI. Select your code and then hit ALT+t or under edit select tabify region.
default start position erchrastil Vizard 2 06-23-2008 09:15 AM
small indentation question dan12345 Vizard 1 03-03-2008 05:57 AM
Default in wireframe semblance Vizard 1 10-16-2006 10:31 AM
Default FOV duda Vizard 1 11-14-2003 01:23 PM
