Old 10-12-2009, 09:12 AM
IGoudt IGoudt is offline
avatar walking over a sequence of points
I would like to have an avatar walk over a sequence of points. I have a network of waypoints, which are connected, and a have an algorithm that finds a path from Begin to End. That path is sent to the function walkRoute(self,avatar,route)
I have the following code:
def walkRoute(self,avatar,route):
for point in route:
    actions.append(vizact.walkTo(point.x,0,point.z)
avatar.addAction(vizact.sequence(actions))
This code allows the avatar to walkto the points on the route, but the problem that I come across with now is that the avatar resets its walking animation (obviously, since they are independent), but I want to have the animation from walking from A to B being "remembered" for the next walkTo from B to C. How can I achieve that? Should animationpaths be the answer, and if so, how can I connect that with walkactions?
Old 10-16-2009, 12:22 PM
When creating a walkTo action, if you pass the value of None as the walk animation, then the action will not modify the animation of the avatar. This allows you to manually play the walk animation when the action sequence begins and stop it when it finishes, so the animation will play continuously through all the actions.
avatar scale and link.setpos conflict? sircedric4 Vizard 0 09-29-2009 08:48 AM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 10:44 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 06:52 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 09:48 AM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 09:15 PM
