Old 09-29-2009, 04:29 AM
Andy Andy is offline
animation sequence
If I have a node3d object and call an animation state, is it possible to stop the action on the last position and start a new action state on this position (like a sequence of animations)?
I my application I would like to move a robotic gripper in a close position and open position.
#add robiGrip - default position is closed
robiGrip = viz.add("gripper.cfg")
def onkeydown(key):
	if key == 'o':
		print 'open'
		robiGrip.setAnimationSpeed(0,1)
		robiGrip.state(1)
	elif key == 'c':
		print 'close'
		robiGrip.state(2)
	elif key == 'p':
		print 'pause'
		robiGrip.setAnimationSpeed(0,0)
	elif key == 'r'
		print 'resume'
Old 10-01-2009, 10:42 AM
You can freeze an animation on the last frame, for example.
female = viz.add('vcc_female.cfg', pos = [0,0,5], euler = [180,0,0])
female.execute(5, freeze = True)
Then if the second animation starts at that same point the first one stopped it should work.
Animation Tracks.... k_iwan Vizard 2 03-26-2007 05:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
animation sequence pkhoosh Vizard 2 01-23-2006 08:03 AM
avatar animation problems jrodman Vizard 1 01-18-2006 09:12 AM
animation sequence shai Vizard 1 10-27-2004 10:09 AM
