Old 08-20-2009, 02:06 AM
lilio lilio is offline
addWindow only in one special scene
I want to add a second Window in a special scene, like this:
UpperLeftWindow = viz.addWindow(pos=(0.7,1.0),size=(0.3,0.3))
But this window should only be added in the scene 3.
How can I define the scene, where the window will be added?
Thanks a lot.
Old 08-20-2009, 10:45 AM
Window objects are not dependent on which scene is visible. You will need to manually show/hide the window when scene 3 becomes active/inactive. You can do this by using the UpperLeftWindow.visible command.
How to show different objects on different windows from the same scene Joran Vizard 3 07-14-2014 04:07 PM
Active scene Chrissy2009 Vizard 2 07-13-2009 10:49 AM
How to access scene information in a C++ modifier m7ossny Plug-in development 1 03-23-2007 12:02 PM
saving the scene giancamati Vizard 1 12-21-2006 10:25 AM
Collision with avatars and scene not working JvdBosch Vizard 12 09-14-2006 07:01 PM
