Old 08-18-2009, 12:43 PM
GiudiceLab GiudiceLab is offline
Question selection of multiple properties, code help?
I am trying to modify some sound object properties on the fly, so I can hear the differences as I make changes. I know the changes will be updated without restarting the script, because I can make this work with presets.
I want to be able to select the property I want to change from a list and then use an input value to update the property.
def modifySettings(gr):
	settings = ['Environment','EnvSize','EnvDiffusion','RoomHF','RoomLF','DecayTime','DecayHFRatio','DecayLFRatio',
'Reflections','ReflectionsDelay','ReflectionsPan','Reverb','ReverbDelay','ReverbPan','EchoTime','EchoDepth',
'ModulationTime','ModulationDepth','AirAbsorptionHF','HFReference','LFReference','RoomRolloffFactor','Flags']
	select = viz.choose('Modify which setting?',settings)
	set = viz.input('Set '+settings[select]+' to')
	if settings[select] == 'Environment':
		gr.Environment = set
(twenty more elifs...)
		print 'I cannot change that setting'
Basically, I don't want to write a bunch of if statements unless I have to, so is there a simple way of doing this? Something that would be kind of like:
gr.settings[select] = set
Virtual Environments and Multimodal Interaction (VEMI) Lab
This time, it should work...
Old 08-18-2009, 12:54 PM
There are a few ways to accomplish this. If all the choice strings exactly match the attribute name on the gr object, then you can use the following code:
	name = settings[viz.choose('Modify which setting?',settings)]
	value = viz.input('Set '+name+' to')
	setattr(gr,name,value)
Old 08-19-2009, 03:45 PM
Talking
Sweet. Worked like a charm. Thanks!
output to multiple (two) sound devices GiudiceLab Vizard 1 08-05-2009 01:12 PM
Any ideas on linking chess 3ds file with source code? djones1010 Vizard 1 04-24-2009 09:56 PM
multiple objects durf Vizard 1 04-10-2009 01:42 PM
Vizard Tip of the Month: Use Tasks to Simplify your Code Gladsomebeast Vizard 5 05-02-2008 04:30 PM
tracking with multiple LEDS dan12345 Precision Position Tracker (PPT) 7 04-02-2008 10:44 PM
