Old 07-09-2009, 11:25 AM
jsnider jsnider is offline
one side texture
I want to put a target on one side of a box. It seems that textures would work the best. I tried
target=viz.add('box.wrl')
pic = viz.addTexture('tex.jpg')
target.texture(pic)
where tex.jpg is a 256x256 image of a bullseye, but it puts the texture on all sides (as I assume it should). Is there anyway around that or a different approach that would work better?
Joe
Old 07-09-2009, 12:52 PM
You can use the undocumented vizshape module to create a box with each face split into a separate sub-node, allowing you to apply a different texture. Here is some sample code:
import vizshape
#Create box with each face split into separate sub-node
box = vizshape.addBox([1,1,1],splitFaces=True,pos=(0,1.8,4))
box.addAction(vizact.spin(0,1,0,45))
#Create textures
t1 = viz.add('image1.jpg')
t2 = viz.add('image2.jpg')
#Apply first texture to front/back face
box.texture(t1,node='front')
box.texture(t1,node='back')
#Apply second texture to left/right face
box.texture(t2,node='left')
box.texture(t2,node='right')
Old 07-09-2009, 02:17 PM
Thank you. That worked perfect.
Joe
displayHTML and side by side stereo hosier Vizard 4 08-28-2009 03:21 PM
Translating a texture and its Alpha shivanangel Vizard 5 12-02-2008 04:52 PM
3D Texture Mapping in Vizard? stefs Vizard 2 03-25-2008 03:34 AM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 12:12 PM
