Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 07-01-2009, 06:05 AM
Saz Saz is offline
problems with output to a text file within executable
I'm having trouble getting my data when my program is published as an executable. When developing the code this:
#Get path to publish EXE
path = viz.getOption('Y:\backup\Vizard30\resources\road\speed_.txt','.')+'/'
#Open file in path
file = open( 'adapt' + str(subject),'w' )
worked fine - but didn't work at all when published as an executable.
Previously I've gathered data using this:
directory = 'Z:\Vizard30\Dataoutput\driving\ '
subjectd = 'speed_.txt' + str(subject)
filename = directory+subjectd
file = open(filename, 'w')
which again seems to have stopped working.
I've tried this:
def getPublishedPath(filename):
	filename = 'adapt_.txt' + str(subject)
	publishPath = viz.getOption('Y:\backup\Vizard30\resources\road\','')
	if publishPath:
		return '/'.join([publishPath,filename])
	return filename
file = open(getPublishedPath(filename), 'w')
but I get an error message with it.
Any ideas on what I should be doing?
Cheers!
Old 07-01-2009, 11:01 AM
Take a look at the following thread. There's some sample code in one of farshizzo's posts.
http://forum.worldviz.com/showthread.php?t=715
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
executable file with avatars incorrectly displayed aa-chris Vizard 2 11-03-2008 10:28 AM
How to input several model files and then save one output file mspusch Vizard 1 07-15-2008 10:30 PM
Writing text files with executable adimov Vizard 1 03-21-2008 03:21 PM
text output jaclyn.bill Vizard 2 10-24-2007 06:37 AM
