Old 06-04-2009, 02:31 PM
sl0bz sl0bz is offline
tracking position of cursor
I have a four wall CAVE system with four Flock of Birds trackers using trackd. I am able to start the tracking system using: tracker = viz.add('trackd.dls') and viz.tracker(). For some reason, the system is only tracking the sensor corresponding to the user's head position. Which isn't necessarily a bad thing because now I have a head tracked virtual environment.
However, I would still like to be able to use more than one sensor.
I want to attach one of the sensors to a gamepad device and have a virtual cursor that will allow me to interact with objects in the environment. I have tried using the tracker.get() command but have not been having any luck.
Thanks in advance for the help
sl0bz
Old 06-06-2009, 11:23 PM
Searched the Vizard help for Trackd plug-in:
http://www.worldviz.com/vizhelp/trackd_plug-in.htm
Old 06-15-2009, 07:31 AM
We have looked for help in Vizard's help menu prior to the post, but still had no luck. Any other suggestions?
Old 06-15-2009, 02:52 PM
To add more sensors, methinks you add the trackd.dls again. From the help:
PORT_TRACKD = 1000
head = viz.add('trackd.dls')
hand = viz.add('trackd.dls')
Position and Orientation tracking problem Vic Vizard 1 06-09-2009 06:13 PM
Flock of Birds (Only Position Tracking working? No Orientation?) TheLostBrain Vizard 6 05-10-2008 09:39 AM
position tracking with patriot pgagolf Vizard 4 04-19-2007 05:42 AM
PPT vs. VPRN - Position Tracking not Working tmcw Precision Position Tracker (PPT) 21 02-27-2007 04:19 PM
Tracking and interaction kgarr Vizard 6 08-31-2006 02:06 PM
