Old 05-12-2009, 11:48 AM
Penguin Penguin is offline
custom events within classes
Hi, is it possible to register more than one function for listing on a custom event? When pressing the 'e'-button the following code should print out 'B' and 'C'. But only 'C' is printed out. When I swap the two *.enableEvent(EVENT) lines then 'B' is printed out.
Therefore I guess only one function can listen to an event at the same time. Am I right?
class A(object):
	def __init__(self):
		pass
	def enableEvent(self, EventID):
		viz.callback(EventID,self.doit)
	def doit(self):
		pass
class B(A):
	def __init__(self):
		pass
	def doit(self):
		print "B"
class C(A):
	def __init__(self):
		pass
	def doit(self):
		print "C"
EVENT = viz.getEventID('EVENT')
b = B()
b.enableEvent(EVENT)
c = C()
c.enableEvent(EVENT)
def sendEvent():
	viz.sendEvent(EVENT)
vizact.onkeydown('e',sendEvent)
Old 05-12-2009, 12:04 PM
Yes, have a look in the documentation under the Reference -> Events -> Event basics section. It contains sample code showing how to use the viz.EventClass for registering multiple objects with an event.
Old 05-12-2009, 12:09 PM
the vizact.onevent function is pritty handy for this too
Paul Elliott
WorldViz LLC
Old 05-12-2009, 02:42 PM
Hm, could you illustrate it on my sample code please? I had a look on the event classes but I don't know how to process my own event in class A respectively B and C.
The vizact.onevent documentation is unfortunately to scarce.
Old 05-12-2009, 03:10 PM
class A(object):
	def __init__(self):
		pass
		vizact.onevent(EventID, lambda : (True,None),self.doit)
Paul Elliott
WorldViz LLC
Howto debug a custom plugin? reedev Plug-in development 3 04-23-2009 02:16 PM
Adding custom faces mjabon Vizard 2 04-01-2009 08:34 PM
How do I add custom functions to a custom plugin? reedev Plug-in development 7 02-01-2009 03:39 AM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 10:30 AM
Creating Custom Avatar Heads farshizzo Vizard 22 09-12-2004 09:23 PM
