Old 05-12-2009, 01:33 AM
Chrissy2009 Chrissy2009 is offline
Draw Line between Points
I want to create a line between two points. The first point at the mouseDown Position and the second point at the mouseUp Position. Between these two points I want to draw a line.
This works very fine.
But now I want to show the line, before the mouseUp Event. So that I push down the mousebutton, move it at another position and can already see the line, although the mousebutton is pushed.
The line would change as long as I push the mousebutton.
Is this possible?
Thanks in advance...
Old 05-12-2009, 09:12 AM
Yes, this is definitely possible. Here is a sample script that uses the viztask module to draw lines with the mouse:
import viztask
def DrawLineTask():
	while True:
		#Wait for left mouse butten to be pressed
		yield viztask.waitMouseDown(viz.MOUSEBUTTON_LEFT)
		#Get mouse position
		pos = viz.mouse.getPosition()
		#Create line
		viz.startlayer(viz.LINES)
		viz.vertexcolor(viz.RED)
		viz.vertex(pos[0],pos[1],0)
		line = viz.endlayer(parent=viz.SCREEN)
		#Create link between mouse position and vertex
		VertexLink = viz.link(viz.Mouse,line.Vertex(1))
		#Wait for mouse button to be released
		yield viztask.waitMouseUp(viz.MOUSEBUTTON_LEFT)
		#Destroy link
		VertexLink.remove()
viztask.schedule( DrawLineTask() )
Old 05-13-2009, 04:42 AM
thanks a lot!
And how can I stop the schedule, so I'm able to draw only two lines and no more??
Is there a possibility to save the separate positions of all these four vertex?
Pivot points for child objects in Vizard with 3ds Max Gladsomebeast Vizard 0 09-19-2006 11:21 AM
problem with collision detection paulpars Vizard 6 06-09-2006 06:03 PM
Draw Line between Points selected by mouse Johannes Vizard 7 01-07-2005 02:50 PM
