Old 04-27-2009, 12:35 AM
nasr nasr is offline
how to pick up the object, move and rotate using mouse
hello all,
im trying to develop an application using which i have to pick, drag, move and rotate the object using mouse...i have download the boxstacker and turbine demos for grabbing the objects...but they are executing when im launching the applications... could some one plz tell the code how this could be accomplished..
thankyou..
Old 04-27-2009, 06:15 PM
The following code creates a mousetracker object from the Viztracker module. The hand gets linked to this mousetracker. When you pick an object it gets linked to the hand.
import viztracker
tracker = viztracker.MousePos()
#Add the object that will do the grabbing and link it to the tracker
hand = viz.add('marker.wrl')
viz.link(tracker, hand)
#turn off mouse navigation
viz.mouse(viz.OFF)
#Add the object that the marker will grab
ball = viz.add( 'ball.wrl' )
ball.translate( 0.5, 1.5, 3 )
link = None
#Grab or let go of the ball
def toggleLink():
	global link
	if link:
		#If link exits, stop grabbing
		link.remove()
		link = None
	elif vizmat.Distance(hand.getPosition(), ball.getPosition()) < .5:
		link = viz.grab( hand, ball )
vizact.onpick(ball,toggleLink)
Old 05-03-2009, 12:59 AM
thanks jeff for ur reply...i tried with ur code..the mouse pointer is linked with the marker, but why it isnot able to move the ball?
import viztracker
viz.mouse(viz.OFF)
link = None
def toggleLink():
	global link
	if link:
		link.remove()
		link = None
Old 05-04-2009, 10:10 AM
It works, you just have to line up the marker with the ball in the z coordinate. In order to do that you need to move the mouse wheel until the marker is right on top of the ball.
Old 05-05-2009, 01:34 AM
its working....thankyou jefff..
Old 05-05-2009, 04:11 AM
jeff....how rotation can be applied for the ball using the mouse.....i want to rotate the object...is it possible?
