Old 03-13-2009, 11:10 AM
levisii levisii is offline
quit an embedded viz-simulation
hi there,
i was creating a frame with wxPython. from this frame i started an embedded viz-simulation. so far it works quite well. (i found everything i need here. thanks for that )
but if i try to close this simulation and start it again form the mainFrame, the new simulation is just gray. the problem is that i am not able to call the viz.quit() function to clean up. as you can see in the code i was testing the function calls by printouts.
the viz.EXIT_EVENT is not executed before i close the wxPython mainFrame.
my onKeyDown() function does the test print as it should be done, but it ignores the viz.quit() without an error.
i hope you can help me.
here is my code:
#wxFrame class
import wx
import ducks #this is my testsimulation
class MainFrame(wx.Frame):
def __init__(self, parent, id, title):
wx.Frame.__init__(self, parent, id, title)
#Menubar
menubar = wx.MenuBar()
worldViz = wx.Menu()
worldViz.Append(104, '&Simulation', 'Start a 3D-simulation')
self.SetMenuBar(menubar)
wx.EVT_MENU(self, 104, self.onStart3D)
def onStart3D(self, event):
self.timer = wx.Timer(self, 5000) #timer to refresh the simulation
self.timer.Start(10)
wx.EVT_TIMER(self, 5000, self.onTimer)
self.sim = viz.go(viz.EMBEDDED)
test = ducks.simulation()
def onTimer(self, event):
viz.updateframe()
#my testsimulation class
def simulation():
viz.clearcolor(0.5, 0.5, 1.0)
#Set ViewPoint
view = viz.MainView
view.setPosition(0, 1, -20)
#Turn on the physics engine
viz.phys.enable()
#Add ground
ground.collidePlane()
#Exit-function
def onkeydown(key): #exit the simulation if you press 1
if key == '1':
print 'test'
viz.quit()
viz.callback(viz.KEYDOWN_EVENT, onkeydown)
def onexit():
print 'onexit executed'
viz.quit()
viz.callback(viz.EXIT_EVENT, onexit)
#this is the starting class
import wx
from MainFrame import *
class MainApp(wx.App):
def OnInit(self):
frame = MainFrame(None,-1, 'Phantom')
frame.Show(True)
return True
app = MainApp(0)
app.MainLoop()
del app
Old 03-13-2009, 11:40 AM
Please repost the code using the [code][/code] tags. This will preserve the indentation which is need to run Python code.
Old 03-14-2009, 04:17 AM
oh, i'm sorry. first time i'm posting here
i've splitted my code to one files per class, but if you run this, it is showing my problem:
import viz, wx
#This class implements the GUI-Frame
        #Menubar
        menubar.Append(worldViz, '&WorldViz')
        self.CreateStatusBar()
    #calls the embedded simulation
        self.timer = wx.Timer(self, 5000)   #Timer for updating the frames
        simulation()
    #Manuel FrameUpdate
        viz.updateframe()
#this is my test simulation
def simulation():
    #Set ViewPoint
    view = viz.MainView
    viz.phys.enable()
    #Add ground
#Exit-function
def onkeydown(key):
    if key == '1':
        print 'onKeyDown() executed'
        viz.quit()
def onexit():
    print'onExit() executed'
    viz.quit()
	def OnInit(self):
		frame.Show(True)
		return True
app = MainApp(0)
app.MainLoop()
del app
Old 03-20-2009, 08:34 AM
Hello? Can anybody help me?
Old 03-24-2009, 11:21 AM
Are you trying to exit your entire application when the key is pressed, or just close the Vizard window?
If you are trying to exit the entire app, then you need to call the Close() method of your MainFrame class.
If you want to just close the Vizard window, then this is not possible. You can only call viz.go() once, so you can only create a single Vizard window for the duration of your script. To deal with this limitation you can create the Vizard window during startup and make the window visible/hidden to simulate creating/destroying the window.
Old 04-01-2009, 03:39 AM
Thank you very mutch for this information. It helps me a lot. I try to exit the Vizard window and create another one while the main frame is running. But I will handle this by antoher way.
vizard quit automatically in full screen stereo mode fuyonggang Vizard 3 09-15-2008 09:51 AM
closing files on a force quit vadrian Vizard 1 02-14-2005 11:38 AM
embedded Vizard tavaksai Vizard 5 12-21-2004 07:49 AM
