Old 02-24-2009, 09:46 AM
durf durf is offline
PPT movement in small area using vizard 3.0
Im trying to move an object in a virtual world across a good distance. In the real world I only have a 10' x 10' room to work with. When I move the sensor about 4' the object in the virtual world doesnt move to far. Is there anyway to increase the movement in the virtual world with the amount of room I have to work with in the real world?
IE. I move 4 feet the object moves like a inch on the screen.
I want: If I move 4 feet the object moves like 6 inches on the screen.
Any thoughts or code?
Old 02-24-2009, 10:15 AM
You can apply a scale factor on your position data. This will apply a scale factor of 2 for x,y, and z using the link of the sensor and object
link.postScale([2,2,2],target=viz.LINK_POS_OP)
Old 02-24-2009, 10:25 AM
I assume that if I have a link already:
ballLink = viz.link(ppt, ball)
I would put that line that you sent after it.
Do I set it equal to something or just to ballLink?
Old 02-24-2009, 10:34 AM
Nevermind I got it!!!!!!!!!!!!!!!!
PPT movement in small area durf Precision Position Tracker (PPT) 1 02-26-2009 01:02 PM
Vizard and Augmented Reality realvision Vizard 4 04-04-2008 11:59 AM
Small Vizard programming Jobs? realvision Announcements 0 03-17-2008 09:53 AM
Fall 2007 release of Vizard R3 3 D Announcements 0 10-15-2007 05:50 PM
