Old 02-20-2009, 08:50 AM
durf durf is offline
2D or 3D array help?
I want to create an array in a 3D enviroment. I have a wrl file that I want to be positioned on a flat surface multiple times. Will call the wrl file "blocks".
I would imagine that I would need some for loop to construct this but I am a little unaware of how python does this. I am use to Java and C++ creations of 2D arrays so I would imagine that the 3D array would have an x, y and z for positioning.
I want to construct these blocks 40 x 30 side by side on the same plane. I do not want to overlap them either. Could I please get some examples on how to construct this. Or is there a user friendly website that I could be pointed to. I am new to python so my knowledge base is limited to how python works.
Thanks Much
Old 02-20-2009, 11:57 AM
Here is an example script that shows how to create a 2D array of objects and position them in a grid structure. Let me know if anything is unclear.
#Width, height of grid
GRID_SIZE = [10,5]
#Spacing between grid items
GRID_SPACING = 1.0
#2D array of blocks
blocks = []
#Iterate over x-axis
for x in range(GRID_SIZE[0]):
	column = []
	#Iterate over y-axis
	for y in range(GRID_SIZE[1]):
		#Create block (copy file from cache)
		b = viz.add('white_ball.wrl',cache=viz.CACHE_COPY)
		#Position block in grid
		b.setPosition(x*GRID_SPACING,0,y*GRID_SPACING)
		#Add block to current column
		column.append(b)
	blocks.append(column)
#Set color of block (3,1) to red
blocks[3][1].color(viz.RED)
#Add environment
import vizshape
vizshape.addGrid(color=[0.2]*3)
viz.clearcolor(viz.GRAY)
#Setup camera navigation
import vizcam
cam = vizcam.PivotNavigate(center=(0,0,0))
cam.rotateTo(0,10,-20)
Pick porblem with arrays shivanangel Vizard 3 08-27-2007 11:10 AM
Avatars in an array and link/unlink betancourtb82 Vizard 7 09-05-2006 05:06 PM
Multidimensional Arrays betancourtb82 Vizard 12 05-04-2006 03:13 PM
Copy objects in an array to another array Johannes Vizard 3 04-29-2005 03:37 PM
spinto cade_mccall Vizard 3 09-09-2004 05:37 PM
