Old 02-10-2009, 11:26 PM
nlfrnassimi nlfrnassimi is offline
how can I stop an action?
I've solved the problem of selecting and moving an object but now I can't deselect the object.
when I choose my first object and move it, it works properly but when i select my second object the first one moves also. how can i stop the first one?
this is the code i wrote:
viz.add('tut_ground.wrl')
viz.clearcolor(0.5,0.5,1)
soccerball1 = viz.add('soccerball.ive')
soccerball2 = viz.add('soccerball.ive')
soccerball3 = viz.add('soccerball.ive')
soccerball1.translate(-1,1.5,3)
soccerball2.translate(0,1.5,3)
soccerball3.translate(1,1.5,3)
arrow = viz.add('arrow.wrl')
arrow.scale(.1,.1,.1)
arrow.visible(viz.OFF)
def mouseclick(button):
ball = viz.pick()
if ball.valid():
vizact.whilekeydown( viz.KEY_UP, ball.translate, 0, vizact.elapsed(1), 0, viz.REL_PARENT )
vizact.whilekeydown( viz.KEY_DOWN, ball.translate, 0, vizact.elapsed(-1), 0, viz.REL_PARENT )
vizact.whilekeydown( viz.KEY_RIGHT, ball.translate, vizact.elapsed(1), 0, 0, viz.REL_PARENT )
vizact.whilekeydown( viz.KEY_LEFT, ball.translate, vizact.elapsed(-1), 0, 0, viz.REL_PARENT )
pos = ball.get(viz.POSITION)
pos[1] +=.2
arrow.translate(pos)
arrow.visible(viz.ON)
viz.callback(viz.MOUSEDOWN_EVENT,mouseclick)
viz.mouse(viz.OFF)
Old 02-11-2009, 02:54 AM
moooh moooh is offline
vizact.whilekeydown will be added as events that will listen to the specified keystrokes. When you click the first ball, the events for the first ball will be created. When you click the second ball the events for the second ball will be added to the chain of events that listen to KEY_UP etc. This already includes the events of the first ball since you are creating new events instead of replacing the old.
The ball variable is also in local scope in the mouseclick function so any change you make to it (the assignment of the new ball through ball = viz.pick() for instance) will not affect the global ball variable.
What you should do is move the vizact statements out of the function and replace the second argument with a function of your own. This function could handle the translation for you. This way you'll only have 1 event for each key.
change the mouseclick function to only handle the picking of a ball
    global ball    #global reference to the ball
        pickObj = viz.pick()
        if pickObj.valid():
            ball = pickObj   #assign the current chosen ball to the global variable
and outside of this function add the event registers now with a call to your function instead with the pressed key as the third argument.
vizact.whilekeydown( viz.KEY_UP, myTranslate, viz.KEY_UP )
vizact.whilekeydown( viz.KEY_DOWN, myTranslate, viz.KEY_DOWN )
vizact.whilekeydown( viz.KEY_RIGHT, myTranslate, viz.KEY_RIGHT )
vizact.whilekeydown( viz.KEY_LEFT, myTranslate, viz.KEY_LEFT )
and create the translate function
def myTranslate(key):
    global ball
    if not ball:  #no ball selected, don't try to translate
        return
        if key == viz.KEY_UP:  #up is being pressed
            ball.translate  #... add the rest of the up translation of the ball here
        elif key == viz.KEY_DOWN:
            ball.translate # ... add the rest of the down translation of the ball here
        elif key == viz.KEY_LEFT:
            ball.translate # ... add the rest of the left translation of the ball here
        elif key == viz.KEY_RIGHT:
            ball.translate # ... add the rest of the right translation of the ball here
This way you will only translate the currently chosen ball as the key events will always call the same myTranslate function regardless of which ball is chosen.
Old 02-11-2009, 06:54 PM
Thanks for your help. Still I'm having problem with giving value to translate. when I assign value to it, the ball suddenly disappears.
Please check the code.
global ball
if pickObj.valid():
ball = pickObj
ground.disable(viz.PICKING)
global ball
if not ball:
return
ball.translate(0,1)
ball.translate()
ball.translate()
elif key == viz.KEY_KP_LEFT:
ball.translate()
vizact.whilekeydown(viz.KEY_UP,myTranslate,viz.KEY _UP)
vizact.whilekeydown(viz.KEY_DOWN,myTranslate, viz.KEY_DOWN)
vizact.whilekeydown(viz.KEY_RIGHT,myTranslate, viz.KEY_KP_RIGHT)
vizact.whilekeydown(viz.KEY_LEFT,myTranslate, viz.KEY_KP_LEFT)
viz.mouse(viz.OFF)
Old 02-11-2009, 07:24 PM
I have solved the problem of assigning value to translate, the only problem left is that the right ball jumps when I try to move it but the other 2 works perfect.
global ball
if pickObj.valid():
ball = pickObj
global ball
if not ball:
return
ball.translate(0,0.01,0,ball)
ball.translate(0,-0.01,0,ball)
ball.translate(0.01,0,0,ball)
ball.translate(-0.01,0,0,ball)
vizact.whilekeydown(viz.KEY_RIGHT,myTranslate, viz.KEY_RIGHT)
vizact.whilekeydown(viz.KEY_LEFT,myTranslate, viz.KEY_LEFT)
viz.mouse(viz.OFF)
Old 02-13-2009, 01:59 AM
That is odd. The 3 balls are dealt with in the exact same way so having only 1 of them not behaving as intended is strange. In what way the third ball jumping? The only thing I can see about your code is that you have accidently put a space in the last argument of viz.KEY_UP in the whilekeydown statement.
Stop for... loop Johannes Vizard 20 04-01-2014 02:53 AM
How to stop vizact.move Jerry Vizard 3 06-04-2009 05:25 PM
delays with <avatar>.act and speech vsully Vizard 15 08-23-2007 05:24 PM
When a video stop ? djdesmangles Vizard 2 01-11-2007 05:15 PM
download problems & avatar action vgracie Vizard 1 09-14-2006 12:29 PM
